[fusion-users] how to download the latest SVN version
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Fri Nov 20 03:02:33 EST 2009
Try the procedure described here:
http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Thanks Kenneth for your answer. I have tried what you say but I got the
> following message:
> Can't create directory 'D:\Program
> Files\OSGeo\MapGuide\Web\www\fusion\.svn':
> denied access.
> I have window vista 32 ultimate and I am the administrator of this machine.
> What could be it happening?
> Regards,
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You should use "Checkout" instead of "Import", and there should be no
>> password prompt for that.
>> The Checkout command will get you a fresh copy of Fusion, which you can
>> then "Update" to get the latest fixes.
>> The "Import" command attempts to write your files into Fusion, which
>> only comitters may do.
>>> Hi all,
>>> I have already installed the tortoise SVN application in my machine and
>>> when
>>> I want to connect to SVN fusion version as of my FUSION folder(right
>>> click
>>> and next click in tortoiseSVN - Import) then tortoise ask me for a user
>>> and
>>> password. Next I put my user and password of SVN server that I created
>>> previously but
>>> I can't access to SVN fusion.
>>> any suggestion will be well appreciated.
>>> Regards,
>>> Rodolfo Moreno
>>> CivilEng
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Rodolfo Moreno
> CivilEng
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20091120/ecbfa8d3/attachment.html
More information about the fusion-users
