[fusion-users] how to download the latest SVN version
Rodolfo Moreno rodolfoamoreno at gmail.com
Wed Nov 25 05:33:19 EST 2009
Thanks Kenneth and Jason.
According to the recommendation from Jason(I don't know why his post is not
showed in the present thread or at least I can't see it, but his suggestion
is in my inbox mail) I have deactivated the UAC configuration of window
vista and I haven't already gotten the access problem. However I have gotten
other error:
Failed to add file 'D:\Program Files\OSGeo\MapGuide\Web\www\fusion\text\en':
a
non-file object of the same name already exists
which could be the problem?
Kenneth Skovhede, GEOGRAF A/S wrote:
> Try the procedure described here:
> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rodolfo Moreno skrev:
>> Thanks Kenneth for your answer. I have tried what you say but I got the
>> following message:
>> Can't create directory 'D:\Program
>> Files\OSGeo\MapGuide\Web\www\fusion\.svn':
>> denied access.
>> I have window vista 32 ultimate and I am the administrator of this
>> machine.
>> What could be it happening?
>> Regards,
>>> You should use "Checkout" instead of "Import", and there should be no
>>> password prompt for that.
>>> The Checkout command will get you a fresh copy of Fusion, which you can
>>> then "Update" to get the latest fixes.
>>> The "Import" command attempts to write your files into Fusion, which
>>> only comitters may do.
>>>> Hi all,
>>>> I have already installed the tortoise SVN application in my machine and
>>>> when
>>>> I want to connect to SVN fusion version as of my FUSION folder(right
>>>> click
>>>> and next click in tortoiseSVN - Import) then tortoise ask me for a user
>>>> and
>>>> password. Next I put my user and password of SVN server that I created
>>>> previously but
>>>> I can't access to SVN fusion.
>>>> any suggestion will be well appreciated.
>>>> Regards,
>>>> Rodolfo Moreno
>>>> CivilEng
>>> fusion-users mailing list
>>> fusion-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>> Rodolfo Moreno
>> CivilEng
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/how-to-download-the-latest-SVN-version-tp3997693p4064061.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
