[fusion-users] how to download the latest SVN version
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Nov 25 07:04:53 EST 2009
Most likely there is a folder named "en" but the checkout wants to place
a file there called "en".
Try deleting the "en" folder before performing the checkout.
If the checkin was made on a case-sensitive filesystem (like ext for
linux) there can be a folder called
"EN" and a file called "en". If this is the case (which i doubt), you
cannot checkout on windows :(.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Thanks Kenneth and Jason.
> According to the recommendation from Jason(I don't know why his post is not
> showed in the present thread or at least I can't see it, but his suggestion
> is in my inbox mail) I have deactivated the UAC configuration of window
> vista and I haven't already gotten the access problem. However I have gotten
> other error:
> Failed to add file 'D:\Program Files\OSGeo\MapGuide\Web\www\fusion\text\en':
> a
> non-file object of the same name already exists
> which could be the problem?
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Try the procedure described here:
>> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html
>>> Thanks Kenneth for your answer. I have tried what you say but I got the
>>> following message:
>>> Can't create directory 'D:\Program
>>> Files\OSGeo\MapGuide\Web\www\fusion\.svn':
>>> denied access.
>>> I have window vista 32 ultimate and I am the administrator of this
>>> machine.
>>> What could be it happening?
>>> Regards,
>>>> You should use "Checkout" instead of "Import", and there should be no
>>>> password prompt for that.
>>>> The Checkout command will get you a fresh copy of Fusion, which you can
>>>> then "Update" to get the latest fixes.
>>>> The "Import" command attempts to write your files into Fusion, which
>>>> only comitters may do.
>>>>> Hi all,
>>>>> I have already installed the tortoise SVN application in my machine and
>>>>> when
>>>>> I want to connect to SVN fusion version as of my FUSION folder(right
>>>>> click
>>>>> and next click in tortoiseSVN - Import) then tortoise ask me for a user
>>>>> and
>>>>> password. Next I put my user and password of SVN server that I created
>>>>> previously but
>>>>> I can't access to SVN fusion.
>>>>> any suggestion will be well appreciated.
>>>>> Regards,
>>>>> Rodolfo Moreno
>>>>> CivilEng
>>>> _______________________________________________
>>>> fusion-users mailing list
>>>> fusion-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>> Rodolfo Moreno
>>> CivilEng
> Rodolfo Moreno
> CivilEng
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20091125/e24e99f7/attachment.html
More information about the fusion-users mailing list
