[fusion-users] how to download the latest SVN version
Jason Birch jason at jasonbirch.com
Wed Nov 25 11:39:36 EST 2009
Doh.  I keep forgetting that Fusion is not reply-all by default.
Original message:
You're writing to program files; do you have UAC turned off? Being
admin isn't good enough these days...
Try setting the repo up in your user area, then copying over.
You're not trying to check out directly into the MapGuide fusion directory
installation are you?  That won't work because it contains files that aren't
under version control.  You need to:
 svn checkout to a different location
 rename old MapGuide fusion directory
 svn export (or use Ant to build/deploy) fusion to the correct MapGuide
location
 optionally, copy custom MapGuide fusion templates back to the fusion
install dir
There are (outdated) notes on how to build using Ant here:
http://n2.nabble.com/Fusion-Load-Time-was-Fusion-Oracle-datasource-problem-td2061603.html
Jason
Jason
2009/11/25 Rodolfo Moreno
> Thanks Kenneth and Jason.
> According to the recommendation from Jason(I don't know why his post is not
> showed in the present thread or at least I can't see it, but his suggestion
> is in my inbox mail) I have deactivated the UAC configuration of window
> vista and I haven't already gotten the access problem. However I have
> gotten
> other error:
> Failed to add file 'D:\Program
> Files\OSGeo\MapGuide\Web\www\fusion\text\en':
> a
> non-file object of the same name already exists
> which could be the problem?
> Kenneth Skovhede, GEOGRAF A/S wrote:
> > Try the procedure described here:
> > http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html
> > Regards, Kenneth Skovhede, GEOGRAF A/S
> > Rodolfo Moreno skrev:
> >> Thanks Kenneth for your answer. I have tried what you say but I got the
> >> following message:
> >> Can't create directory 'D:\Program
> >> Files\OSGeo\MapGuide\Web\www\fusion\.svn':
> >> denied access.
> >> I have window vista 32 ultimate and I am the administrator of this
> >> machine.
> >> What could be it happening?
> >> Regards,
> >>> You should use "Checkout" instead of "Import", and there should be no
> >>> password prompt for that.
> >>> The Checkout command will get you a fresh copy of Fusion, which you can
> >>> then "Update" to get the latest fixes.
> >>> The "Import" command attempts to write your files into Fusion, which
> >>> only comitters may do.
> >>>> Hi all,
> >>>> I have already installed the tortoise SVN application in my machine
> and
> >>>> when
> >>>> I want to connect to SVN fusion version as of my FUSION folder(right
> >>>> click
> >>>> and next click in tortoiseSVN - Import) then tortoise ask me for a
> user
> >>>> and
> >>>> password. Next I put my user and password of SVN server that I created
> >>>> previously but
> >>>> I can't access to SVN fusion.
> >>>> any suggestion will be well appreciated.
> >>>> Regards,
> >>>> Rodolfo Moreno
> >>>> CivilEng
> >>> _______________________________________________
> >>> fusion-users mailing list
> >>> fusion-users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> >> Rodolfo Moreno
> >> CivilEng
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/how-to-download-the-latest-SVN-version-tp3997693p4064061.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20091125/9056d325/attachment.html
More information about the fusion-users mailing list
