[Gdal-dev] [RFC] RasterIO speedup patch
Tim Beckmann tbeckman at usgs.gov
Wed Feb 5 17:31:02 EST 2003
Frank and the rest of the list,
We've been working to incorporate GDAL into our software.  One drawback
we've found so far is that the performance of gdal when it needs to do
data type conversions is extremely slow.  Here is a patch that I've
generated that seems to work to improve the performance.  It works by
changing the GDALRasterBand::IRasterIO to attempt to convert more than a
single pixel for every call to GDALCopyWords.  For the testing I've done,
it seems to work well.  I'm not sure if I've covered all the possible
combinations though.  There are still cases where it falls back to calling
GDALCopyWords once for each pixel.
Some preliminary timings show that the runtime to convert a 100 MB Float32
image to Byte data took 49 seconds with the original code, but only 27
seconds with the patch below.  This is using our unreleased LAS driver on
an SGI Origin 2000 with 250 MHz processors.
Any comments?
Oh yeah, once for the record - I really dislike the naming convention used
for variables in the routine.  It makes it much harder to understand the
code.  Also, some of the variable names could use some comments to explain
what they do (I'd add them, but I'm not 100% sure).  Example: the
nSrcPixelOffset parameter to GDALCopyWords.  If I understand it correctly,
it isn't an offset, it is the value to stride through the data with.
I also have another set of changes that cut the time nearly in half
again...  But one step at a time.
Patch (hopefully won't be mangled by my email program):
--- ../../../remotesensing_gdal/core/rasterio.cpp       Mon Nov 11
10:02:06 2002
+++ rasterio.cpp        Wed Feb  5 15:58:02 2003
@@ -103,6 +113,8 @@
     int         nBandDataSize = GDALGetDataTypeSize( eDataType ) / 8;
+    int bytesPerDataPixel = GDALGetDataTypeSize( eDataType ) / 8;
+    int bytesPerBufPixel = GDALGetDataTypeSize( eBufType ) / 8;
     GByte       *pabySrcBlock = NULL;
     GDALRasterBlock *poBlock;
     int         nLBlockX=-1, nLBlockY=-1, iBufYOff, iBufXOff, iSrcY;
@@ -231,6 +243,26 @@
                     return CE_Failure;
+            /* calculate buffer span in the current block and handle as
many
+               pixels as possible in one call to the GDALCopyWords
routine.
+               Note: this makes sure that if the data is being subsampled
at
+               somethings besides an integer interval that only one pixel
at a
+               time is grabbed.  This is very inefficient.  It would
likely be
+               better to convert the entire line, then pull out the
pixels that
+               are needed for the subsampled version. */
+            int iSrcXInc = (int)dfSrcXInc;
+            int wordCount = 1;
+            if ( dfSrcXInc == iSrcXInc)
+                /* integer multiple for subsampling, so calculate the
number
+                   of words to copy.  Also make sure the end of the
requested
+                   bytes isn't exceeded. */
+                int endXBlockIndex = (nLBlockX + 1) * nBlockXSize;
+                wordCount = (endXBlockIndex - iSrcX)/iSrcXInc;
+                if (wordCount > (nBufXSize - iBufXOff))
+                    wordCount = nBufXSize - iBufXOff;
 /*      Copy over this pixel of data. */
@@ -239,29 +271,38 @@
             if( eDataType == eBufType )
+                /* FIXME: it might be better to call GDALCopyWords to
process
+                   all the pixels from the current buffer */
                 if( eRWFlag == GF_Read )
                     memcpy( ((GByte *) pData) + iBufOffset,
                             pabySrcBlock + iSrcOffset, nBandDataSize );
                 else
                     memcpy( pabySrcBlock + iSrcOffset,
                             ((GByte *) pData) + iBufOffset, nBandDataSize
+                iBufOffset += nPixelSpace;
             else
-                /* type to type conversion ... ouch, this is expensive
way
-                   of handling single words */
+                /* copy all the words for the current image block */
-                    GDALCopyWords( pabySrcBlock + iSrcOffset, eDataType,
0,
-                                   ((GByte *) pData) + iBufOffset,
eBufType, 0,
-                                   1 );
+                    GDALCopyWords( pabySrcBlock + iSrcOffset, eDataType,
+                                   bytesPerDataPixel * iSrcXInc,
+                                   ((GByte *) pData) + iBufOffset,
eBufType,
+                                   bytesPerBufPixel * iSrcXInc, wordCount
                 else
-                    GDALCopyWords( ((GByte *) pData) + iBufOffset,
eBufType, 0,
-                                   pabySrcBlock + iSrcOffset, eDataType,
0,
-                                   1 );
+                    GDALCopyWords( ((GByte *) pData) + iBufOffset,
eBufType,
+                                   pabySrcBlock + iSrcOffset, eDataType,
wordCount );
+                /* adjust the loop counter to account for copying
multiple
+                   words - ugly I know */
+                iBufXOff += (wordCount - 1);
+                iBufOffset += (nPixelSpace * wordCount);
-            iBufOffset += nPixelSpace;
Interesting timing data for converting a 100 MB image with Float32 data to
Byte data (using our LAS driver that hasn't been released yet):
Quick summary: original code took 49 seconds.  patched code took 27
seconds.
*****Original timing:
Summary of ideal time data (ideal)--
                    9537549636: Total number of instructions executed
                   12281429794: Total computed cycles
                        49.126: Total computed execution time (secs.)
                         1.288: Average cycles / instruction
Function list, in descending order by exclusive ideal time
 [index]   excl.secs   excl.%     cum.%        cycles  instructions calls
function  (dso: file, line)
     [1]      25.279    51.5%     51.5%    6319710000    5075915000
25020000  GDALCopyWords (libgdal.1.1.so: rasterio.cpp, 369)
     [2]      18.711    38.1%     89.5%    4677785000    2951650000 10000
GDALRasterBand::IRasterIO(GDALRWFlag,int,int,int,int,void*,int,int,GDALDataType,int,int)
(libgdal.1.1.so: rasterio.cpp, 114)
     [3]       4.934    10.0%     99.6%    1233501577    1460605855
50030709  memcpy (libc.so.1: bcopy.s, 329)
     [4]       0.019     0.0%     99.6%       4874107       5695887 5062
memset (libc.so.1: bzero.s, 98)
***** Timing with the patch:
                    5839329727: Total number of instructions executed
                    6783873165: Total computed cycles
                        27.135: Total computed execution time (secs.)
                         1.162: Average cycles / instruction
     [1]      21.979    81.0%     81.0%    5494875000    4326065000 25000
GDALCopyWords (libgdal.1.1.so: rasterio.cpp, 400)
     [2]       4.934    18.2%     99.2%    1233501840    1460606163
50030721  memcpy (libc.so.1: bcopy.s, 329)
     [3]       0.019     0.1%     99.3%       4874107       5695887 5062
     [4]       0.018     0.1%     99.3%       4515000       2710000 10000
Software Project Lead
SAIC
EROS Data Center, Sioux Falls, SD 57198
605-594-2521    Phone
605-594-6940    Fax
