[Gdal-dev] Re: Why is origin different?
Thu Feb 20 09:48:57 EST 2003
Diana Esch-Mosher wrote:
> I have the following method. The file I am trying to copy has no
> geotransform or projection or metadata. The file I create has the
> origin  0,1? Why? Both are HFA files.
> Thanks,
> Diana
> def CopyDatasetInfo( self,src, dst ):
>         if src.GetGCPCount() > 0:
>             dst.SetGCPs( src.GetGCPs(), src.GetGCPProjection() )
>         dst.SetGeoTransform( src.GetGeoTransform() )
>         dst.SetProjection( src.GetProjection() )
>         dst.SetMetadata( src.GetMetadata() )
Diana,
I have committed a fix for this bug.  I also modified the Imagine writing
code to not write out a "mapinfo" node for images with the default
geotransform (unreferenced).
I have cc:ed this to gdal-dev since that is a more appropriate venue for
GDAL specific issues.
Best regards,
