[Gdal-dev] Oracle OGR Segmentation Fault
Wim Blanken w.blanken at geon.nl
Thu Sep 4 10:08:14 EDT 2003
Hello Frank,
Thank you for your answer. I think I found the problem. The Layers I tried
to access didn't have a gid at all. I used ogrinfo with a layer that was not
imported using ogr2ogr but had a gid. This layer worked allright. So i think
ogr wants a gid with a unique record number.
Regards,
Wim Blanken
> Wim Blanken wrote:
> > Hello List,
> > I am experimenting with ogr in combination with oracle and having the
> > following problem.
> > Using ogrinfo with layers that have been loaded using ogr2ogr is not a
> > problem but existing layers (not loaded with ogr2ogr) are producing
> > segmentation faults. I noticed that the ogr2ogr layers have an OGR_FID
> > column and that the other layers not. Is this the problem. Is there a
> > solutions to this problem?
> Wim,
> Ogrinfo and ogr2ogr are certainly intended to work fine without the
OGR_FID
> field but I must confess this case is likely tested significantly less
than
> layers loaded with ogr2ogr itself.  It is quite possible that some more
> esoteric field types are not handled well.
> If you can provide a set of SQL I can run through sqlplus to prepare a
table
> that will reproduce the problem then I will look into it, otherwise there
> isn't much I can do from my end without access to your system to debug the
> issue.  From your end it would be helpful if you could build GDAL/OGR in
> debug and produce a traceback of failed access.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
