[Gdal-dev] Re: porting of gdal to (optional) libtool build finally completed
Alessandro Amici alexamici at tiscali.it
Thu Sep 25 16:54:53 EDT 2003
> I concur ... you can make "with libtool" the default, as --without-libtool
> works to make things as they are now.  If we don't change the default, it
> is unlikely the mechanism will get much testing and I would like it to be
> the default for the 1.2.0 release relatively soon.
will do soon.
BTW, do you have a timeline for the next release?
and a list of the must-have, must-fix items?
> Good work!
alessandro
BTW: external xerces compiles fine as well.
