[Gdal-dev] Problems building gdal dll with libtool on MinGW
Alessandro Amici alexamici at fastwebnet.it
Wed Feb 18 03:52:38 EST 2004
Mario,
On Wednesday 18 February 2004 07:33, Mario Beauchamp wrote:
> Hi Alessandro,
> I was hoping you would jump in since I knew you were one of the few on the
> list familiar with MinGW
well, familiar is far too much ;)
> As you may have read in my other post, I finally chose to build GDAL as a
> static lib and inside the Dev-Cpp environment (ie no MSYS) and everything
> is fine now, althought it took a whole day of fiddling to fine tune the
> Dev-Cpp project file...
why did you go for dev-cpp for building the static library (which i belive is
a lot of work!)? did you have any problem with the gdal static build?
i'd think that just doing 'configure' 'make' 'make install' 'a2dll' should
work as well (but i cannot try it since i don't have any windows box at the
moment)
cheers,
alessandro
