[Gdal-dev] The whole dataset in memory?
Mon Jan 5 12:18:50 EST 2004
Petteri Packalen wrote:
> Hi,
> Is there any way in GDAL to load the whole dataset in memory? VRT
> Dataset can be created "in memory", but is it possible to load actual
> pixel data to memory as well. I would need as fast access to band data as
> possible (memory consumption is not a problem).
Petteri,
There is an all-in-memory driver (the MEM driver).  If you were to do a
CreateCopy() to that format you would have the data all-in-memory for sure.
However, normally it is sufficient to set the cache size up to be large enough
to hold the entire dataset and then do a pre-read pass to pull the data into
the cache.   The cache size can be set with GDALSetCacheMax(), the argument
being an integer cache size in bytes.
Best regards,
