[Gdal-dev] Create method
Gillian Walter gillian.walter at atlantis-scientific.com
Fri Sep 24 11:09:25 EDT 2004
What is a VRTFuncSource?  I didn't see it on:
http://gdal.maptools.org/gdal_vrttut.html
Do you have any VRT snippets lying around that shows what it looks like?
Gillian
Frank Warmerdam wrote:
> Julien Demaria wrote:
>> good solution... have you got a simple example code which do that, if
>> possible ?
> Julien,
> I'm afraid I do not.  The key is to create a VRT data and
> VRTSourcedRasterBand
> and then add a VRTFuncSource to it.  The function in the VRTFuncSource
> will be
> called as imagery is needed.
> Best regards,
