[Gdal-dev] Problems installing gdal-grass-1.3.1
Fri Dec 9 12:56:30 EST 2005
On 12/9/05, Maik Trömel <maik.troemel at maitro.net> wrote:
> Hello ,
> I've got a problem installing gdal-grass-1.3.1 from binarys. Up till now
> nobody was able to help me.
Maik,
I did a few patches after 1.3.1 release for AMD64
systems, which included more agressive use of -fPIC.
I don't know if that might be an issue for your case or
not, but you might want to try a nightly snapshot of GDAL
and see if you have any better luck.
Best regards,
