[Gdal-dev] projection lost when translating HDF to GTiff
Brent Fraser bfraser at geoanalytic.com
Tue Jul 12 15:42:14 EDT 2005
Thom,
  Do you get a coord sys defined when you do a "gdalinfo" on the hdf file?
Brent
----- Original Message -----
From: "Thom DeCarlo" <t.r.decarlo at larc.nasa.gov>
To: <gdal-dev at xserve.flids.com>
Sent: Tuesday, July 12, 2005 11:52 AM
Subject: [Gdal-dev] projection lost when translating HDF to GTiff
I gave up on compiling the HDF4 code myself and found that the binary bundle
will work with a couple of tweaks.
Anyway, I've got a bunch of ASTER DEM files that I need to convert to
geotiff and I'm losing the geographic projection info when I do the simple
"gdal_translate -of GTiff input.hdf output.tif"
I looked at the online docs and didn't see anything special needed to do
this translate. Can someone tell me what I'm missing?
Thanks,
Thom
Thom DeCarlo
          It is ok to celebrate diversity...
As long as you don't point out that people are different.
                                - Colin Quinn
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
