[Gdal-dev] gdal install errors
    Yves Jacolin
    yjacolin at free.fr
    Thu Nov  9 10:05:39 EST 2006
Le Jeudi 9 Novembre 2006 15:57, Martin Wegmann a écrit :
> Hello,
> I tried on a fresh debian testing system to install the official gdal 1.3.2
> source code and the cvs code (today), both resulted in the error messages
> below when executing make.
> Any hint, how to fix it is appreciated.
> regards, Martin
> ./configure --with-grass=/usr/local/grass-6.3.cvs/
> GDAL is now configured for i686-pc-linux-gnu
>   Installation directory:    /usr/local
>   C compiler:                gcc -O2
>   C++ compiler:              g++ -O2
>   LIBTOOL support:           yes
>   LIBZ support:              external
>   GRASS support:             grass57+
>   CFITSIO support:           no
>   PCRaster support:          internal
>   NETCDF support:            no
>   LIBPNG support:            internal
>   LIBTIFF support:           internal
>   LIBGEOTIFF support:        internal
>   LIBJPEG support:           internal
>   LIBGIF support:            internal
>   OGDI support:              no
>   HDF4 support:              no
>   HDF5 support:              no
>   KAKADU support:            no
>   JASPER support:            no
>   ECW support:               no
>   MrSID support:             no
>   CURL support (wcs):        no
>   POSTGRESQL support:        yes
>   MySQL support:             no
>   XERCES support:            no
>   ODBC support:              no
>   PGEO support:              no
>   OCI support:               no
>   SDE support:               no
>   DODS support:              no
>   SQLite support:            no
>   DWGdirect support          no
>   PANORAMA GIS support:      no
>   GEOS support:
>   Statically link PROJ.4:    no
>   Traditional Python:        yes
>   NG SWIG Bindings:
>   enable OGR building:       yes
> #make
> make[2]: Nothing to be done for `install-obj'.
> make[2]: Leaving directory
> `/home/baliola/software/gdal_cvs/gdal/frmts/pcraster'
> make -C grass install-obj
> make[2]: Entering directory
> `/home/baliola/software/gdal_cvs/gdal/frmts/grass' /bin/sh
> /home/baliola/software/gdal_cvs/gdal/libtool --mode=compile g++ -Wall  -O2
>  -I/usr/local/grass-6.3.cvs//include
> -I/home/baliola/software/gdal_cvs/gdal/port
> -I/home/baliola/software/gdal_cvs/gdal/gcore
> -I/home/baliola/software/gdal_cvs/gdal/alg
> -I/home/baliola/software/gdal_cvs/gdal/ogr
> -I/home/baliola/software/gdal_cvs/gdal/ogr/ogrsf_frmts -DOGR_ENABLED
> -I/home/baliola/software/gdal_cvs/gdal/port  -c -o ../o/grass57dataset.o
> grass57dataset.cpp
> g++ -Wall -O2 -I/usr/local/grass-6.3.cvs//include
> -I/home/baliola/software/gdal_cvs/gdal/port -c grass57dataset.cpp  -fPIC
> -DPIC -o ../o/.libs/grass57dataset.o
> grass57dataset.cpp: In static member function 'static GDALDataset*
> GRASSDataset::Open(GDALOpenInfo*)':
> grass57dataset.cpp:948: error: 'GPJ_grass_to_wkt' was not declared in this
> scope
> make[2]: *** [../o/grass57dataset.o] Error 1
> `/home/baliola/software/gdal_cvs/gdal/frmts/grass' make[1]: ***
> [grass-install-obj] Error 2
> make[1]: Leaving directory `/home/baliola/software/gdal_cvs/gdal/frmts'
> make: *** [frmts-target] Error 2
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
In the installation doc about grass, it is wrote to
1/ build gdal with the --without-grass flag
2/ build Grass
3/ build gdal-grass
I advice you to follow the documentation.
Regards,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
