[Gdal-dev] Proposal for Unified Windows Binaries
Howard Butler hobu at iastate.edu
Mon Apr 16 08:53:41 EDT 2007
On Apr 16, 2007, at 1:31 AM, Ari Jolma wrote:
> Frank Warmerdam kirjoitti:
>> Generally speaking if you use the C API I *think* there should be
>> no cross-heap / cross-runtime problems but I'm not 100% sure of this
>> myself.  I'm imagining shipping a core built with VC7.1.
> The current bindings use the C API but they also use the Colortable
> class C++ API. That may cause some problems when trying to use a
> GDAL DLL built with other compiler than what you are using.
We need to add C API for the GDALColorTable and GDALColorEntry stuff
to reconcile this issue.
Howard
