[Gdal-dev] Re: RFC 10
Thu Nov 15 13:47:09 EST 2007
Mateusz Loskot wrote:
> Frank Warmerdam wrote:
>> I'm not clear on why RFC 10 couldn't be altered to provide a standard
>> mechanism to encode parameters into the datasource name and go from there.
>> The issue of applications which don't know the format apriori is not new.
> I think it might be not easy to find common syntax used across all
> drivers. For example, if we decided to delimit options with @, perhaps
> there are some drivers that use @ token in its native connection string.
> IMO, options interface should be defined as common to all drivers, but
> not using syntax specific to a driver.
Mateusz,
Yes, that was my intent.  To "package" lists of options in a standard way
with well understood escaping and quoting rules.  A mechanism that could
be applied to new drivers, and in some hopefully not-too-disruptive fashion
applied to old drivers with options in the datasource name.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
