[gdal-dev] fwtools 2.1.0, gdal1.6 and oci, sde plugins
Duarte Carreira DCarreira at edia.pt
Wed Apr 9 13:16:36 EDT 2008
Howard,
What is the simplest way you know of to have FWTools work with these
plugins? I'm afraid I didn't quite understand your suggestion at the end
of your message. Should I start using gdal releases instead of fwtools
if I need oci and sde?
Thanks,
Duarte
-----Mensagem original-----
De: Howard Butler [mailto:hobu.inc at gmail.com]
Enviada: quarta-feira, 9 de Abril de 2008 17:14
Para: Duarte Carreira
Cc: gdal-dev at lists.osgeo.org
Assunto: Re: [gdal-dev] fwtools 2.1.0, gdal1.6 and oci, sde plugins
On Apr 8, 2008, at 10:14 AM, Duarte Carreira wrote:
> Hello.
> I'm trying to use FWTools 2.1.0 with OCI and SDE plugins and get
> errors related to wrong versions conflicts. OGR says gdal14.dll is not
> found, and GDAL complains about SDE driver being compiled against GDAL
> 1.5 and current version is 1.6.
> Are new plugins expected soon? And is there a workaround?
> Thanks everyone for your help.
Duarte,
Our stable windows release located at
http://download.osgeo.org/gdal/win32/1.5/
  provides a full complement of current plugins for ArcSDE and OCI
(along with some others like MrSID and ECW).  I have found it quite
taxing to keep up building plugins for both FWTools and our stable
releases, and with the new OSGeo4W effort, I have focused my effort on
these because they should work in OSGeo4W as well.
If you need to track GDAL trunk for a bug fix or new feature, I'm afraid
you'll have to invest some effort in building your own plugins (or
linking in what you need directly for even easier usage).
Howard
