[gdal-dev] GDAL Releases
Even Rouault even.rouault at mines-paris.org
Wed Oct 8 17:31:08 EDT 2008
FYI, with the fix done in http://trac.osgeo.org/gdal/ticket/2297, I've
successfully built GDAL trunk with a HDF5 1.8.1 library (built from the
source without any particular config option).
And I can also build it with libhdf4g-4.1r4-21 from the Ubuntu repository
If you have specific problems, it may be interesting to (re)open tickets with
precise informations on your configure options and libraries versions.
