[gdal-dev] GDAL Releases
Andrew Brooks arb at sat.dundee.ac.uk
Thu Oct 9 13:27:59 EDT 2008
On Wed, 08 Oct 2008 22:31:08 +0100, Even Rouault <even.rouault at mines-paris.org> wrote:
> FYI, with the fix done in http://trac.osgeo.org/gdal/ticket/2297, I've
> successfully built GDAL trunk with a HDF5 1.8.1 library (built from the
> source without any particular config option).
You're right about hdf5, sorry, I was convinced I had to modify it but
your fix was sufficient.
However I did have to modify the following files to get gdal to build:
frmts/hdf4/hdf4imagedataset.cpp
frmts/hdf4/hdf-eos/SWapi.c
frmts/hdf4/hdf-eos/GDapi.c
frmts/hdf4/hdf4dataset.cpp
Andrew
