[gdal-dev] Installing test databases/servers online for the GDAL project
Even Rouault even.rouault at mines-paris.org
Tue Oct 28 15:09:57 EDT 2008
As far as pgsql and mysql are concerned, the first few lines of ogr_pg.py and
ogr_mysql.py describe what is required to set up the databases. For these
ones, it is pretty easy. For the other servers, I can't say.
For the record:
# To create the required PostGIS instance do something like:
#  $ createdb autotest
#  $ createlang plpgsql autotest
#  $ psql autotest < ~/postgis.sql
# To create the required MySQL instance do something like:
#  $ mysql -u root -p
#     mysql> CREATE DATABASE autotest;
#     mysql> GRANT ALL ON autotest.*
TO 'THE_USER_THAT_RUNS_AUTOTEST'@'localhost';
Le Tuesday 28 October 2008 13:31:29, vous avez écrit :
> Folks,
> I'm not totally sure whether this topic has already been discussed or
> not, however I'd like to see your opinion about.
> I've just worked on adding further drivers to Windows buildbot slaves,
> as I consider it would be reasonable to have them regularly tested
> especialy during the beta/release period of the GDAL project. I've
> noticed that many of the tests rely on the existence of some external
> servers like for mysql, oci, sde, pgsql, wcs. Currently none of these
> servers are available online therefore those tests are skipped in the
> testing process.
> I'd wonder if we could somehow get those servers online, however I'm
> not sure who is responsible to maintain the corresponding databases.
> Assuming that there's no explicit owner of these servers would it be
> reasonable to establish such test servers for the GDAL project
> permanently?
> Another benefit of such an addition would be that the developers could
> track down and fix issues related to these drivers without having to
> wait for the component owner to take the required action. Most of the
> developers (like me) cannot afford spending such amount of $$$ to have
> those servers (like SDE or Oracle Spatial) installed locally, but I
> sometimes have a couple of issues reported with SDE and OCI which
> should be handled in short term.
> One of the issues have to be considered in this topic is a security
> related problem, I guess it's undesired to allow everyone to have
> read/write access to those databases, however I think we could
> separate those connection strings from the autotest scripts and load
> them from an external file by the scripts.
> I expect the GDAL project could collect enough sponsorship to support
> and mainain these servers or we could also establish that OSGEO-wide
> if the idea seems reasonable for the other projects as well.
> Any ideas?
> Best regards,
> Tamas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
