[gdal-dev] reading VPF format NGA DNCs
Christopher Barker Chris.Barker at noaa.gov
Thu Jan 14 18:33:19 EST 2010
Frank Warmerdam wrote:
> For what it's worth, the connection string I use is:
>   gltp:/vrf/home/warmerda/data/vpf/dnc13/h1316010
> Within the h1316010 directory I have files in lower case:
> warmerda at gdal64[105]% ls h1316010/
> cat  dqy  env  hyd  lcr  libref  lineage.doc  obs  rel
> cul  ecr  grt  iwy  lht  lim     nav          por  tileref
> The driver is (I believe) case sensitive on linux/unix.
That would explain it those are all upper-case on my machine -- I'll try
lower-casing everything and see what I get.
thanks,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
