[gdal-dev] Re: Bug(?): RIK-maps with Gdal 1.7.2 do not work
Tomas R monshi at home.se
Wed Jul 7 12:58:45 EDT 2010
  The fix in
http://trac.osgeo.org/gdal/changeset/19985
I can download and replace the file in the 1.7.2 version of gdal I have
and compile gdal again and it will work?
Or should I wait for 1.7.3?
Yours
Tomas
Tomas R skrev 2010-07-06 20:02:
>  So a solution/a fix is available when 1.7.3 is released somewhere in
> the future? That somewhere might occur when?
> If you are correct that is. But of course you are....
> /Tomas
> Even Rouault skrev 2010-07-06 19:46:
>> Chaitanya,
>> Actually I think I've spotted the regression in
>> http://trac.osgeo.org/gdal/changeset/17398, which was a 1.7 change.
>> Namely the change from
>> int i;
>> for( i = 0; i<  LZW_CLEAR; i++ )
>>     character[i] = i;
>> to
>> GByte j;
>> for( j = 0; j<  LZW_CLEAR; j++ )
>>     character[j] = j;
>> The issue is that LZW_CLEAR = 256, so as j is an unsigned char -
>> restricted
>> from 0 to 255 -, the j<  LZW_CLEAR condition is always true, thus the
>> infinite loop...
>> This part should be reverted. If you really want to shut up the compiler
>> warning character[i] = (GByte)i but in an ideal world, the compiler
>> should be
>> clever enough to see that there's no risk of data loss as i does fit
>> in a
>> GByte...
>> Best regards,
>> Even
>> Le Tuesday 06 July 2010 19:18:56 Tomas R, vous avez écrit :
>>>    The reason for the out of memory exception was because the RIK-map I
>>> tested with i wasfar to big to be read into a bitmap. I have now
>>> created
>>> a smaller sample.
>>> With the small RIK-fil I can reproduce the problem with the precompiled
>>> binaries from dyndns so problem is not only on my part. Using the small
>>> map (1000x750 pixels) the demo app from Gdal 1.6.1 works as it should.
>>> 1.7.2 hangs with no exception given.
>>> See ticket http://trac.osgeo.org/gdal/ticket/3674
>>> The post you answered  I tried to delete and somewhat succeeded... I
>>> happened to compile the wrong file. When I thought I was compiling the
>>> GDALReadDirect.cs I instead compiled the GDALRead.cs.
>>> Yours
>>> Tomas
>>> Chaitanya kumar CH skrev 2010-07-06 18:24:
>>>> Tomas,
>>>> I don't see any changes that could lead to infinite loops or memory
>>>> leaks recently.
>>>> If you can provide a sample dataset that gives this error please raise
>>>> a ticket at http://trac.osgeo.org/gdal/newticket
>>>> On Tue, Jul 6, 2010 at 6:43 PM, Tomas R<monshi at home.se
>>>> <mailto:monshi at home.se>>  wrote:
>>>>       I add - perhaps a problem with my comilation of Gdal.  Note when
>>>>      I compile the GdalReadDirect.cs as it is and run it the result
>>>>      differs from the result of the GdalReadDirect.exe found in
>>>>      Swig\Csharp.
>>>>      The latter gives the Raster dataset Paramets and runs until an
>>>> Out
>>>>      of memory Exception. Mine hangs and I have to abort it.
>>>>      What have I done wrong this time?
>>>>      Will try to recompile gdal and see if anything changes.
>>>>      Tomas R skrev 2010-07-06 14:16:
>>>>           I have a problem with RIK-maps and Gdal 1.7.2.
>>>>          If I use Gdal 1.6.1 I have no problem reading the map but
>>>>          doing the same with Gdal 1.7.2 my whole plugin/software
>>>> hangs.
>>>>          I have identified that Gdal stops at the line
>>>>           band.ReadRaster(x, y, width, height, r, width, height, 0,
>>>> 0);
>>>>          where x, y, width and height are controlled to be within the
>>>>          image to load.
>>>>          This line taken from the routine
>>>>           private void SaveBitmapPaletteDirect(...)
>>>>          from the C# samples. I have adapted it to load only a portion
>>>>          of the map into a bitmap.
>>>>          I have compiled Gdal myself, perhaps a problem with the
>>>>          compilation? Do I miss the RIK-driver or something? Or is
>>>>          there an error in Gdal?  Or perhaps in the file(s)?
>>>>          I have no problem opening and getting the properties of the
>>>>          file, i.e. coordinate system and alike. It is when I try to
>>>>          read the file that Gdal hangs.
>>>>          I get no Exception, it just hangs and eats CPU-time.
>>>>          I  compile the C# sample GDALReadDirect.cs from Gdal 1.7.2
>>>> and
>>>>          adapt it to read a portion of a big RIK file (500x500 pixels)
>>>>          and it stops at the same point in code. Error in the driver
>>>>          for RIK perhaps? or error in the sample code?
>>>>          Yours
>>>>          Tomas
>>>>      _______________________________________________
>>>>      gdal-dev mailing list
>>>>      gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
>>>>      http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
