[gdal-dev] Unable to load CIB datasets with GDAL
Ryan McKinley ryantxu at gmail.com
Fri Nov 19 15:46:50 EST 2010
Perhaps related...  I have an .I24 file that fails to read in GDAL,
but works OK in ArcCatalog 9.3 (in 10 it fails, since they now use
GDAL!)
Running a recent /trunk build, I get:
$ ./gdalinfo.exe "F:\...\rpf\file.i24"
ERROR 1: Image header too small (called from line 606)
gdalinfo failed - unable to open 'F:\...\rpf\file.i24'.
$ ./gdalinfo.exe --debug ON "F:\...\rpf\file.i24"
GDAL: GDALDeregister_GTiff() called.
not sure if this is helpful or not
ryan
On Fri, Nov 19, 2010 at 2:00 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> morabit wrote:
>> Hi All,
>>  In our project we are using GDAL 1.7.2 to load map data in various
>> formats
>> as CADRG, DTED, CIB, etc.
>> All it's working fine but we have a big problem with the CIB format. For
>> this type of datasets, the GDALOpen function fails with the following
>> error message:
>> 'For <frameFileName>, assert 'geoTransf[GEOTRSFRM_ROTATION_PARAM1] == 0 &&
>> geoTransf[GEOTRSFRM_ROTATION_PARAM2] == 0' failed.'
>>  We checked the source code and discovered that this was due to a series
>> of
>> assert failures in file rpftocdataset.cpp, lines 733, 740.
>>  We tried to comment out this asserts, but now the same function fails
>> with
>> the following error message:
>> 'Ignoring NITF RPF Location table since it seems to be corrupt.'
>>  We are pretty sure that our datasets are not corrupted, as the same
>> datasets
>> are loaded without any problems by Global Mapper v12.00 and FalconView
>> 4.3.0.
>> The gdalinfo tool seems to handle these files with no problems but if we
>> use
>> it with the -mm option the following errors are reported:
>> Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
>>  ERROR 6: File lacks VQ LUTs, unable to decode image
>> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
>> ERROR 6: File lacks VQ LUTs, unable to decode imagery
>> ERROR 1: IReadBlock failed at X offset 1, Y offset 0
>> ERROR 1: Failed to compute min/max, no valid pixels found in sampling.
> Bruno,
> Could you create a ticket in the GDAL trac for this issue?  When I run
> the nitfdump utility against the .I42 file I get messages like:
> ERROR 1: Cannot read RPFIMG TRE. Not enough bytes : remaining 1350, expected
> 1400
> Do you see anything similar when accessing the full file?
> This might be an issue easier for Even to review as he wrote the RPFTOC
> driver.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
