[gdal-dev] hdf5image metadata problems
Antonio Valentino antonio.valentino at tiscali.it
Wed Jun 15 18:56:59 EDT 2011
Hi Frank, hi Alex,
Il 15/06/2011 22:34, Frank Warmerdam ha scritto:
> On 11-06-15 03:50 PM, Alex Mantaut wrote:
>> Hi Frank:
>>              Thanks for the swift reply.
>>               Right now it opens the metadata asociated to the root,
>> and also
>> the metadata asociated with all the other groups, but it doesn't open the
>> metadata asociated to the specified element (bug?)
> Alex,
> It sounds like a defect to me, yes.
> I would suggest filing a ticket that carefully documents the
> problem with a supporting example file.
> Best regards,
The current behavior looks fine to me.
If one opens a specific subdataset then only one "HDF5 dataset object"
can be accessed and it is mapped on GDAL raster bans n. 1.
All other "HDF5 dataset object" in the h5 file are ignored by the
HDF5ImageDataset so there is no reason IMHO to make their metadata
available in some manner.
Metadata associated to all HDF5 groups (including the root one) are
available in any case and accessible via GDAL dataset metadata.
my two cents
Antonio Valentino
