[gdal-dev] Problems exporting numPY array to float Geotiff using
OSGEO gdal python bindings
William Hudspeth
wbhk at unm.edu
Wed Mar 2 11:49:06 EST 2011
Hello,
I am trying to export a numPY float array/matrix to a Lambert Conformal
Geotiff/Float32 image. While the script exports an image, all pixel
values are zero. May numpy array seems to be built correctly, and when I
print it, looks like this...
[[ 0.03678615 0.0390082 0.04026087 ..., 0.03603812 0.03531498
0.03276101]
[ 0.03677472 0.03901754 0.04030903 ..., 0.03583324 0.0350121
0.03258276]
[ 0.03676465 0.03900253 0.04031235 ..., 0.03625959 0.03476617
0.03255093]
[ 0.03522387 0.03507313 0.03519889 ..., 0.03515329 0.03527898
0.03535137]
[ 0.03499253 0.03495976 0.03493112 ..., 0.03491645 0.03497614
0.0349773 ]
[ 0.03486236 0.03487948 0.03492932 ..., 0.03490033 0.03487814
0.03489009]]
My python code for the export is:
floatNumPyArray=floatNumPyArray(numpy.float)
format="GTiff"
dst_driver=GetDriverByName(format)
srs=osr.SpatialReference()
srs.ImportFromProj4('+proj=lcc +lat_1=33 +lat_2=45 +lat_0=40 +lon_0=-97
+x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs')
output=dst_driver.Create(LambertOutput.tif,cols,rows,1,GDT_Float32)
lambert_geotransform=[-1440000,4000,0.0,84000,0.0,-4000]
output.SetGeoTransform(lambert_geotransform)
output.SetProjection(srs.ExportToWkt())
output.GetRasterBand(1).WriteArray(floatNumPyArray)
Thanks in advance for any help...
Bill
