[gdal-dev] ArcSDE -> GeoTiff: Bit size calculation failed...
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Oct 14 11:34:42 EDT 2011
Wouter,
Which version of GDAL are you using?
On Fri, Oct 14, 2011 at 8:17 PM, Wouter Schaubroeck <
wouter.schaubroeck at gmail.com> wrote:
> Hey list,
> I'm trying to convert a raster image in ArcSDE to a GeoTiff, but this
> isn't working as expected. I'm getting the following error:
> SDE's length:16834 With bitmap length: 18529 Without bitmap length: 16834
> The error is thrown in the following file:
> sderasterband.cpp, at line 444
> I've searched for this on google, but except for the source code,
> nothing showed up. I've noticed that the first and last number are the
> same, but according the source this isn't possible...
> ArcSDE's stats are up to date, and I can see the image with ArcMap and
> with GeoServer (with the SDE-jars).
> What am I doing wrong here?
> thx, Wouter
> Wouter
> http://blog.giswhat.be
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111014/744065d9/attachment.html
