[gdal-dev] ArcSDE -> GeoTiff: Bit size calculation failed...
Howard Butler hobu.inc at gmail.com
Fri Oct 14 12:04:20 EDT 2011
> SDE's length:16834 With bitmap length: 18529 Without bitmap length: 16834
I was the author of that code, but it has been a number of years since I've done anything with SDE. I believe it has to do with the fact that the raster layer you're reading from has a bitmask (bitmap) on it, and the SDE driver doesn't handle them.  The code probably needs to be updated to either disregard the mask, or handle it as a GDAL MaskBand.
Hope this helps,
