[gdal-dev] Multi image segments in NITF file
Even Rouault even.rouault at mines-paris.org
Wed Feb 22 08:40:04 EST 2012
Selon Livneh Yehiyam <yehil at rafael.co.il>:
> Hi
> Another NITF question.
> I want to create an NITF file with more than one image segment. I used the
> INUM create option to specify the number of image segments.
> Gdalinfo reports the correct number of sub datasets.
> I've noticed that all of the sub-datasets are created in the same size and
> pixel format as the main dataset, while the NITF specification permits
> different size and pixel format.
> Is there a way to specify these parameters for sub-datasets (image segments),
> either when creating the file, or afterwards?
No, there's no convenient interface in GDAL for doing that, so this is indeed a
limitation of the driver. Should probably be doable with a specific syntax of a
new creation option though.
> Another question is how do I write data to these sub-datasets? Just use
> Gdal.Open with the sub-dataset name and rasterIO as usual?
Yes, that should work.
> Thanks
> Yehiyam Livneh
> This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE
> SYSTEMS LTD.
> (hereinafter "RAFAEL") contains confidential information intended for a
> specific individual and purpose, may
> constitute information that is privileged or confidential or otherwise
> protected from disclosure. If you are not
> the intended recipient, you should contact us immediately and thereafter
> delete this message from your
> system. You are hereby notified that any disclosure, copying, dissemination,
> distribution or forwarding of this
> message, or the taking of any action based on it, is strictly prohibited. If
> you have received this e-mail in error,
> please notify us immediately by e-mail mailto:lawraf at rafael.co.il and
> completely delete or destroy any and all
> electronic or other copies of the original message and any attachments
> thereof.
