[gdal-dev] GEOS Ver 3.3.5 and GDAL Ver 1.91
Mateusz Loskot mateusz at loskot.net
Thu Sep 6 03:35:40 PDT 2012
On 5 September 2012 21:16, Kyle Shannon <kyle at pobox.com> wrote:
> Martin,
> Did you by chance use cmake to build geos?  I built 1.9.1 against geos
> 3.3.5, but used cmake when building geos.  It appears the output files are
> named differently when cmake is used.  If you did use cmake, then it looks
> like you need to specify:
Please, remember CMake config for GEOS is experimental.
(I put big red message on the GEOS wiki, but some may oversight it.)
If you encounter any problems with it, please report ticket to GEOS.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120906/7f6ebca7/attachment.html>
