[gdal-dev] ogr2ogr convert e00 to shp
Andreas Oxenstierna ao at t-kartor.se
Sun Feb 17 23:09:45 PST 2013
How complex is your input file(s)?
ArcInfo coverage/E00 can have virtually any number of featureclasses.
However, a coverage have non-redundant geometry with only two primary
geometry sources: point and line. All other featureclasses (polygons,
nodes, multipolys, multilines etc) shares the geometry using internal
pointers but can (and will normally) have different attributes.
If I use ogr on a point-only coverage:
ogr2ogr gridp05.shp gridp05.e00
then one shapefile is created in the "working directory"
If I use ogr on a polygon coverage:
ogr2ogr grid05.shp grid05.e00
then four shapefiles (lines, polygons, labels) are created in a new
directory named grid05.shp
Best Regards
Andreas
> Thanks for the great explanation and help,
> But still I couldn't solve my problem. Shape file which is generated
> by ogr2ogr should be under the working directory as a file not as a
> fiel under the new directory. I mean after run the command
> I would like to see shape file under the working directory
> f30c3.shp
> f30c3.shx
> f30c3.dbf
> This could be done by old version but for new one as I explain it
> created new directory and collect files under that directory..
> I have written another script and it read data under working
> directory. So I have to see files under the working directory.
> Regards
> Murat
> 2013/2/16 Eli Adam <eadam at co.lincoln.or.us
> <mailto:eadam at co.lincoln.or.us>>
>     On Fri, Feb 15, 2013 at 1:25 PM, Murat Beyhan
>     <muratbeyhan28 at gmail.com <mailto:muratbeyhan28 at gmail.com>> wrote:
>     > Dear All,
>     > I deleted existing shp file and I try but It doesn't create
>     individual shp
>     > file under same directory. Always creates  files under directory
>     > avcimport f30c3.e00 f30c3
>     > ogr2ogr -f "ESRI Shapefile"  f30c3.shp  f30c3
>     > this creates file under directory of f30c3.shp and files as same
>     before I
>     > wrote.
>     >  ls f30c3.shp/
>     > ARC.dbf  ARC.shp  ARC.shx  LAB.dbf  LAB.shp  LAB.shx
>     Coverages, http://gdal.org/ogr/drv_avce00.html, can have multiple
>     different geometry types within one file.  It looks like your results
>     include both lines and labels.  A shapefile can not have multiple
>     geometries within one shapefile so at least one of the output
>     shapefiles can't have the same name.   In this case ogr2ogr is
>     generating one for lines (ARC.shp) and one for labels (LAB.shp).  This
>     is probably also one of the reasons that the shapefile driver treats a
>     directory as a dataset and shapefiles as layers within that
>     'dataset/directory'
>     Best Regards, Eli
>     > Then I also used without using coverage file created by avcimport
>     > I have deleted f30c3 coverage directory and files created by the
>     first
>     > method then apply following directly
>     > ogr2ogr -f "ESRI Shapefile"  f30c3.shp  f30c3.e00
>     > this also created directory for the shape file.
>     > it works and behave similar with previous process
>     > I have faced this problem for new version of Gdal Eli.
>     > old version works fine with mandriva but new version of gdal on
>     ubuntu
>     > behave like this. So I really waiting for the solution of this
>     issue.
>     > 2013/2/15 Eli Adam <eadam at co.lincoln.or.us
>     >> Murat,
>     >> > I was creating shp file using ogr2ogr as follows
>     >> > avcimport file.e00 coverage
>     >> > ogr2ogr -f "ESRI Shapefile" file.shp coverage
>     >> > This was worked well for old version of gdal
>     >> > I have installed gdal 1.9 then I have faced such a problem
>     >> > the ogr2ogr command create a directory and shp file located
>     unter that
>     >> > directory.
>     >> > But old version of ogr2ogr was created files under the same
>     directory
>     >> > where
>     >> > you work
>     >> I think that ogr2ogr has (sometimes) created shapefiles in
>     directories
>     >> for a long time before 1.9.
>     >> > the old version of ogr2ogr creates file.shp file.shx file.dbf
>     >> > but new version create directory under working directory
>     called file.shp
>     >> > instead of file.shp file
>     >> > and the shp files located under file.shp directory
>     >> > Please let me know what is differs this resuts.
>     >> > Regards
>     >> > Murat
>     >> The shapefile driver page talks about this some,
>     >> http://gdal.org/ogr/drv_shapefile.html
>     >> I notice similar things (this is with PostGIS datasource).  If the
>     >> output shp file is the same name as input source then the shp is
>     >> created in the specified directory.  If it is a different name,
>     then I
>     >> get a directory.
>     >> ogr2ogr
>     V:\Data\E_addendum\Assessor\2012\nbhd\nbhd_codes_2012_postgis2.shp
>     >> PG:"host=123.12.12.12 user=username dbname=mydatabase
>     >> password=mypassword" taxlots2012_union_valid_nbhd_codes_v1 -a_srs
>     >> "EPSG:2913"
>     >> creates a directory and then the shp (and the shp has the name
>     of the
>     >> original datasource), i.e.
>     V:\Data\E_addendum\Assessor\2012\nbhd\nbhd_codes_2012_postgis2.shp\taxlots2012_union_valid_nbhd_codes_v1.dbf,
>     >> .shp, etc
>     >> ogr2ogr
>     V:\Data\E_addendum\Assessor\2012\nbhd\taxlots2012_union_valid_nbhd_codes_v1.shp
>     >> PG:"host=123.12.12.12 user=username dbname=mydatabase_template
>     >> "EPSG:2913"
>     >> creates the named shp in the directory.
>     >> I have occasionally found this a minor annoyance.  Is there a
>     config
>     >> or creation option to change this?  A search of the email archives
>     >> didn't turn anything up for me.
>     >> Eli
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130218/dc4c2d5f/attachment.html>
