[gdal-dev] ogr2ogr convert e00 to shp
Murat Beyhan muratbeyhan28 at gmail.com
Mon Feb 18 00:38:21 PST 2013
Dear Friends,
Thank you for the explanation you helped me.
I have move files from created directory to the working directory by bash
scripting.
By the way I understood behaviour of ogr more.
Regards.
 Murat
2013/2/18 Andreas Oxenstierna <ao at t-kartor.se>
>  How complex is your input file(s)?
> ArcInfo coverage/E00 can have virtually any number of featureclasses.
> However, a coverage have non-redundant geometry with only two primary
> geometry sources: point and line. All other featureclasses (polygons,
> nodes, multipolys, multilines etc) shares the geometry using internal
> pointers but can (and will normally) have different attributes.
> If I use ogr on a point-only coverage:
> ogr2ogr gridp05.shp gridp05.e00
> then one shapefile is created in the "working directory"
> If I use ogr on a polygon coverage:
> ogr2ogr grid05.shp grid05.e00
> then four shapefiles (lines, polygons, labels) are created in a new
> directory named grid05.shp
> Best Regards
> Andreas
>  Thanks for the great explanation and help,
> But still I couldn't solve my problem. Shape file which is generated by
> ogr2ogr should be under the working directory as a file not as a fiel under
> the new directory. I mean after run the command
> I would like to see shape file under the working directory
> f30c3.shp
> f30c3.shx
> f30c3.dbf
> This could be done by old version but for new one as I explain it created
> new directory and collect files under that directory..
> I have written another script and it read data under working directory. So
> I have to see files under the working directory.
> Regards
> Murat
> 2013/2/16 Eli Adam <eadam at co.lincoln.or.us>
>> On Fri, Feb 15, 2013 at 1:25 PM, Murat Beyhan <muratbeyhan28 at gmail.com>
>> wrote:
>> > Dear All,
>> > I deleted existing shp file and I try but It doesn't create individual
>> shp
>> > file under same directory. Always creates  files under directory
>> > avcimport f30c3.e00 f30c3
>> > ogr2ogr -f "ESRI Shapefile"  f30c3.shp  f30c3
>> > this creates file under directory of f30c3.shp and files as same before
>> I
>> > wrote.
>> >  ls f30c3.shp/
>> > ARC.dbf  ARC.shp  ARC.shx  LAB.dbf  LAB.shp  LAB.shx
>>  Coverages, http://gdal.org/ogr/drv_avce00.html, can have multiple
>> different geometry types within one file.  It looks like your results
>> include both lines and labels.  A shapefile can not have multiple
>> geometries within one shapefile so at least one of the output
>> shapefiles can't have the same name.   In this case ogr2ogr is
>> generating one for lines (ARC.shp) and one for labels (LAB.shp).  This
>> is probably also one of the reasons that the shapefile driver treats a
>> directory as a dataset and shapefiles as layers within that
>> 'dataset/directory'
>> Best Regards, Eli
>> > Then I also used without using coverage file created by avcimport
>> > I have deleted f30c3 coverage directory and files created by the first
>> > method then apply following directly
>> > ogr2ogr -f "ESRI Shapefile"  f30c3.shp  f30c3.e00
>> > this also created directory for the shape file.
>> > it works and behave similar with previous process
>> > I have faced this problem for new version of Gdal Eli.
>> > old version works fine with mandriva but new version of gdal on ubuntu
>> > behave like this. So I really waiting for the solution of this issue.
>> > 2013/2/15 Eli Adam <eadam at co.lincoln.or.us>
>> >> Murat,
>> >> > I was creating shp file using ogr2ogr as follows
>> >> > avcimport file.e00 coverage
>> >> > ogr2ogr -f "ESRI Shapefile" file.shp coverage
>> >> > This was worked well for old version of gdal
>> >> > I have installed gdal 1.9 then I have faced such a problem
>> >> > the ogr2ogr command create a directory and shp file located unter
>> that
>> >> > directory.
>> >> > But old version of ogr2ogr was created files under the same directory
>> >> > where
>> >> > you work
>> >> I think that ogr2ogr has (sometimes) created shapefiles in directories
>> >> for a long time before 1.9.
>> >> > the old version of ogr2ogr creates file.shp file.shx file.dbf
>> >> > but new version create directory under working directory called
>> file.shp
>> >> > instead of file.shp file
>> >> > and the shp files located under file.shp directory
>> >> > Please let me know what is differs this resuts.
>> >> > Regards
>> >> > Murat
>> >> The shapefile driver page talks about this some,
>> >> http://gdal.org/ogr/drv_shapefile.html
>> >> I notice similar things (this is with PostGIS datasource).  If the
>> >> output shp file is the same name as input source then the shp is
>> >> created in the specified directory.  If it is a different name, then I
>> >> get a directory.
>> >> ogr2ogr
>> V:\Data\E_addendum\Assessor\2012\nbhd\nbhd_codes_2012_postgis2.shp
>> >> PG:"host=123.12.12.12 user=username dbname=mydatabase
>> >> password=mypassword" taxlots2012_union_valid_nbhd_codes_v1 -a_srs
>> >> "EPSG:2913"
>> >> creates a directory and then the shp (and the shp has the name of the
>> >> original datasource), i.e.
>> V:\Data\E_addendum\Assessor\2012\nbhd\nbhd_codes_2012_postgis2.shp\taxlots2012_union_valid_nbhd_codes_v1.dbf,
>> >> .shp, etc
>> >> ogr2ogr
>> V:\Data\E_addendum\Assessor\2012\nbhd\taxlots2012_union_valid_nbhd_codes_v1.shp
>> >> PG:"host=123.12.12.12 user=username dbname=mydatabase_template
>> >> "EPSG:2913"
>> >> creates the named shp in the directory.
>> >> I have occasionally found this a minor annoyance.  Is there a config
>> >> or creation option to change this?  A search of the email archives
>> >> didn't turn anything up for me.
>> >> Eli
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130218/1dd750e8/attachment-0001.html>
