[gdal-dev] Adding labels / specifying styles
Tyler Mitchell tyler.mitchell at actian.com
Thu May 2 08:47:18 PDT 2013
On 2013-05-02, at 8:45 AM, Benoît Laurent wrote:
> After that, I am importing my shapefiles in QGis. Maybe, I should create my labels using a Python script based on the added text column ?
You shouldn't have to use Python to draw labels, there are capabilities in the properties for each layer in QGIS that allow you to select which column to use for the label text.  It's really simple :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130502/c1a01fd6/attachment.html>
