[gdal-dev] How to fix gdalwarp warning?
Even Rouault even.rouault at mines-paris.org
Sat Feb 8 15:44:33 PST 2014
Le vendredi 07 février 2014 16:07:46, Jukka Rahkonen a écrit :
> Stephen Woodbridge <woodbri <at> swoodbridge.com> writes:
> > How does one do "Converting the dataset  prior to 24/32 bit is advised."?
> For example with http://www.gdal.org/pct2rgb.html
"gdal_translate -expand rgb" or rgba is an alternative.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
