[gdal-dev] Standard Dev. Environment?
Jay L. jlaura at asu.edu
Fri Jan 10 10:23:48 PST 2014
Success.  Ivan, I used your ./configure flags - stock was also not working
on this VM.
I wonder if the dev. community is large enough to warrant storing a
lightweight Vagrant box image somewhere.
Thanks Frank, Evan and Ivan.
On Fri, Jan 10, 2014 at 9:54 AM, Ivan Lucena <lucena_ivan at hotmail.com>wrote:
> I always build with:
>   --with-libz=internal \
>   --with-png=internal \
>   --with-libtiff=internal \
>   --with-geotiff=internal \
> *  --with-jpeg=internal \*  --with-gif=internal \
>  If that helps...
> > Date: Fri, 10 Jan 2014 17:33:52 +0100
> > From: even.rouault at mines-paris.org
> > To: jlaura at asu.edu
> > CC: gdal-dev at lists.osgeo.org
> > Subject: Re: [gdal-dev] Standard Dev. Environment?
> > Jay,
> > hum it is well possible that the build with --without-jpeg doesn't work
> and that
> > some drivers will try to use it. I haven't tried it for ages. GDAL has an
> > internal version of libjpeg, so when you've no external libjpeg, that
> one will
> > be picked up. I imagine that very few people test --without-jpeg.
> > Frank suggested you to just use plain "./configure". I'd recommend
> strongly that
> > you just to try it. This must work well and autodetect which libs are
> available
> > or not. The BuildingOnUnixWithMinimizedDrivers page you quote represents
> a
> > non-standard configuration of GDAL, so you may hit rough corners.
> > To answer your question concerning the value for --with-jpeg, it is the
> > installation prefix of libjpeg. Typically /usr for system jpeg (but that
> one
> > would be picked up implicitely) or /usr/local (if you've installed your
> own
> > libjpeg).
> > > Evan,
> > > Thanks for the info. One more question for you - make clean worked,
> but I
> > > have hit another issue:
> > > After running `./configure --without-jpeg ...`, `make clean`, `sudo
> make
> > > install`:
> > > /home/vagrant/gdal-1.10.1/libgdal.so: undefined reference to
> > > `jpeg_write_scanlines'
> > > `jpeg_CreateCompress'
> > > `jpeg_read_scanlines'
> > > So lib-jpeg is seen. This doesn't make sense since I have
> --without-jpeg
> > > specified in the config. I looked in the config and must have missed
> it -
> > > does a flag to specify the full PATH to libjpeg exist?
> > > Thanks,
> > > Jay
> > > On Fri, Jan 10, 2014 at 7:24 AM, Even Rouault
> > > <even.rouault at mines-paris.org>wrote:
> > > > Selon "Jay L." <jlaura at asu.edu>:
> > > > > Frank,
> > > > > Thanks for the heads up. I am using the --without-jasper flag as
> part of
> > > > > the ./configure call. Here is the error that I am seeing - that
> led to
> > > > me
> > > > > to believe that the issue is jasper related:
> > > > > make[1]: Entering directory `/home/vagrant/gdal-1.10.1/apps'
> > > > > g++ gdalinfo.o commonutils.o -L/home/vagrant/gdal-1.10.1 -lgdal
> > > > > -lpthread -lm -lrt -ldl -o gdalinfo
> > > > `dec_jpeg2000'
> > > > > collect2: ld returned 1 exit status
> > > > > make[1]: *** [gdalinfo] Error 1
> > > > > make[1]: Leaving directory `/home/vagrant/gdal-1.10.1/apps'
> > > > > make: *** [apps-target] Error 2
> > > > > I did install libjpeg-dev and libjasper-dev in hopes that this
> would
> > > > > alleviate the issue.
> > > > > Perhaps I am pursuing the issue in the wrong direction?
> > > > When you run ./configure several times, make sure to run "make clean"
> > > > between
> > > > the attempts. I'm not clear why you've had this error with the
> > > > "dec_jpeg2000"
> > > > symbol that is defined and used in the GRIB driver (it has a
> definition
> > > > even if
> > > > you don't have Jasper). Anway the "make clean" will probably solve
> it.
> > > > Generally, "./configure" without any particular argument should work
> on
> > > > most
> > > > platforms.
> > > > > Thanks,
> > > > > Jay
> > > > > On Thu, Jan 9, 2014 at 9:33 PM, Frank Warmerdam <
> warmerdam at pobox.com>
> > > > wrote:
> > > > > > Jay,
> > > > > > Are you needing Jasper? Normally a default build ("./configure")
> > > > should
> > > > > > work pretty well on a precise system. I'm guessing you have
> enabled
> > > > jasper
> > > > > > because it is key to what you want to do? If not --without-jasper
> > > > should
> > > > > > be straight forward.
> > > > > > Best regards,
> > > > > > Frank
> > > > > > On Thu, Jan 9, 2014 at 8:00 PM, Jay L. <jlaura at asu.edu> wrote:
> > > > > >> List,
> > > > > >> I wonder if a standard dev. environment exists? I am working to
> > > > extend a
> > > > > >> driver and am having trouble getting an environment working
> that will
> > > > > >> compile. Current setup is a VagrantVM, Ubuntu 12.04 32-bit with
> > > > source
> > > > > >> downloaded from SVN. Attempting to build with minimized
> > > > > drivers<
> > > > http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers
> >as
> > > > > per the build documentation and am having build errors due to
> > > > > >> dec_jpeg2000 (jasper I believe).
> > > > > >> Q: Are devs using a standard environment (or a different flavor
> of
> > > > *nix?)?
> > > > > >> _______________________________________________
> > > > > >> gdal-dev mailing list
> > > > > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > > > > I set the clouds in motion - turn up | Frank Warmerdam,
> > > > > > light and sound - activate the windows |
> http://pobox.com/~warmerdam
> > > > > > and watch the world go round - Rush | Geospatial Software
> Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140110/7ec941a5/attachment-0001.html>
