[gdal-dev] ERROR 1: Too many points (440 out of 441) failed to transform, unable to compute output bounds.
Simon Shak skunkmyrddyn at gmail.com
Mon Sep 15 08:02:05 PDT 2014
I have had this error message show up if the s_srs is not correctly auto
detected or not present in the input file. I have used a combination of
looking through other nonstandard meta data files present with the image
sets or using a program like global mapper which has a good chance at
guessing the correct s_srs and then specifying it with the -s_srs option.
On Sep 12, 2014 11:19 AM, "Andre Joost" <andre+joost at nurfuerspam.de> wrote:
> Am 12.09.2014 04:54, schrieb Love:
>> Hi,
>> The gdalinfo in my post is the gdalinfo of the subdataset 37. I have also
>> tried gdal_translate but when I tried to use gdalwarp using the
>> gdal_translate output, it has error. I really need to use gdalwarp so that
>> I could project the image into epsg:4326(+prj=longlat). If I'm going to
>> use
>> the gdal_translate I am ask to indicate the gcp which is not good in my
>> case because I have many hdf files in my local directory and maybe they
>> have different gcp and I need to batch process them later using the
>> gdalwarp with the +proj=longlat command. What could be the solution?
> gdalwarp needs the -geoloc switch, and the target extent with -te. See
> also <http://osgeo-org.1560.x6.nabble.com/gdal-dev-
> Geolocation-Arrays-td4372909.html>
> There does not seen to be any progress on this issue.
> The values for -te can be found with gdalinfo on the subdataset.
> HTH,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140915/5ab581c6/attachment-0001.html>
