[gdal-dev] Raster attribute tables in GDAL?
jramm jamessramm at gmail.com
Thu May 21 06:14:46 PDT 2015
That sounds great. Does this driver allow you to only write the dbf file
(and not the shp/shx etc files?)
I can't find much on the docs for doing that:
http://www.gdal.org/drv_shapefile.html
I'll have a look through the header files...
On 20 May 2015 at 15:38, Even Rouault-2 [via OSGeo.org] <
ml-node+s1560n5206664h33 at n6.nabble.com> wrote:
> Le mercredi 20 mai 2015 15:57:38, jramm a écrit :
> > Does GDAL have any support for writing ESRI-style raster attribute
> tables?
> > These are the .vat.dbf files that often accompany geotiffs and other
> > formats....
> I wasn't particularly aware of those sidecar files, but looking a bit I
> found
> one sample at https://dl.vecnet.org/files/j67313813
> It seems it is a standard .DBF file, so you can read/write it with the OGR
> Shapefile driver.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5206664&i=0>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Raster-attribute-tables-in-GDAL-tp5206653p5206664.html
>  To unsubscribe from Raster attribute tables in GDAL?, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5206653&code=amFtZXNzcmFtbUBnbWFpbC5jb218NTIwNjY1M3wyMTIyMDM1OTQ5>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Raster-attribute-tables-in-GDAL-tp5206653p5206907.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150521/f7b11bbb/attachment-0001.html>
