[gdal-dev] GDAL testing
Kurt Schwehr schwehr at gmail.com
Mon Sep 14 14:42:58 PDT 2015
Hi Dmitry,
I didn't totally understand your question.  I don't have autotest2 really
out yet.  You are welcome to use the sample test files that I posted in any
way that the Apache 2.0 license allows.
-kurt
On Sun, Sep 6, 2015 at 8:27 AM, Dmitry Baryshnikov <bishop.dev at gmail.com>
wrote:
> Hi Kurt,
> During code sprint in Korea (FOSS4G 2015) I plan to play with new approach
> of CMake fro GDAL. The one of experiments will be try to use CTest. As I
> plan restructure the sources tree, I can try to integrate you work on
> autotest2 and CTest. Also we can try to create new test directory structure
> more compatible for test and sources tree (this is about you wrote:
> Probably should move python code to also match the C++ tree.  e.g.
> tiff_read_test.py -> autotest2/py/frmts/gtiff/tiff_read_test.py).
> How can get you tests? What do I need to use autotest2?
> Best regards,
>     Dmitry
> 05.09.2015 20:37, Kurt Schwehr пишет:
> (Subject change to focus on testing)
> Hi all,
> First off... what GDAL has with autotest, travis-ci and coverity is
> awesome!
> Thoughts / discussion more than welcome!
> For my production work, I'm not able to use the autotest python code
> because of its non-unittest architecture.  So... I started creating python
> unittest and C++ gunit based tests.  I use autotest2 in Google's internal
> continuous integration system in our main code base.  I'm using Google's
> build system... I've got nothing started for running the C++ tests outside
> of Google.
> Apologies for not even getting out at least samples of autotest2 for folks
> to inspect and comment on.  My intention is to put what I have in a git
> repo and the to start discussions as to what (if anything) GDAL community
> wants to do with autotest2.    I was hoping to get a lot more coverage and
> get GDAL 2.x.x support, but that will have to come later.  It's only 14K
> lines at this point (optimistically 2-3% done), but it has been a huge help
> for me especially with in upgrading versions of gdal and catching bugs in
> support libs & development toolchains.
> The tests are more focused on test isolation than autotest.  This allows
> for a lot more parallelism in testing.  e.g.  It's fair game to run all
> tests at the same time on the same machine.
> find . -name \*.py | xargs wc -l | tail -1
>  10684 total
> find . -name \*.cc -o -name \*.h | xargs wc -l | tail -1
>   3734 total
> Where GDAL's autotest is 204K lines:
>   193994 total
> find . -name \*.c\* -o -name \*.h | xargs wc -l | tail -1
>    10471 total
> Here are some samples:
> C++ tests use  C++11, gunit, google logging, gflags:  (Hoping for C++14
> soon.. e.g. make_unique)
> - autotest2/cpp/port/cpl_conv_test.cc
> <https://gist.github.com/schwehr/13137d826763763fb031> (Yes, this is
> massively boring code)
> - autotest2/cpp/ogr/ogrpoint_test.cc
> <https://gist.github.com/schwehr/c8ee86a6f6a1c1cc043b>
> - autotest2/cpp/ogr/ogrsf_frmts/geojson/geojson_test.cc
> <https://gist.github.com/schwehr/bc44b91a37cd621212c4>
> Python pretty much follows the autotest layout, but with util files in the
> same directory.  Assumes python 2.7 or >= 3.4 (have not tried py3 yet)
> - autotest2/gcore/gcore_util.py
> <https://gist.github.com/schwehr/c143927ca25d03a10265>
> - autotest2/gdrivers/gdrivers_util.py
> <https://gist.github.com/schwehr/dd75f73cedf8f7b5357e>
> - autotest2/gdrivers/tiff_read_test.py
> <https://gist.github.com/schwehr/a35b2bc8a7956ef1f620> (I'm leading
> towards moving driver tests in gcore to gdrivers)
> - autotest2/ogr/geojson_test.py
> <https://gist.github.com/schwehr/6cbdc3482055d2237ad2>
> I'm (mostly) following Google's style guides.  Public versions here: C++
> <https://google-styleguide.googlecode.com/svn/trunk/cppguide.html> Python
> <https://google-styleguide.googlecode.com/svn/trunk/pyguide.html>
> All C++ should be formatted with "clang-format --style=Google"
> What does autotest2 not do?
> Would like to eventually do (unsorted):
> - Test error handling on a range of corrupt data sources
> - Fuzz testing, ASAN/MSAN/TSAN/Valgrind/Heap checks  (I've done some MSAN
> & heap checkers by hand)
> - Performance testing - time and memory usage
> - Test the C API at the C level
> - Test platforms other than Linux (MS Win*, Mac OSX, Android, iOS, other
> embedded oses, BSD*, Solaris, HPUX, etc)
> - Have more detailed language binding tests for java, ruby, perl, php
> - Coverage checking
> - Test parallel processing and multithreading
> - Test networking (I need to think through isolation)
> - Test multiple configurations (e.g. all drivers and features enables vrs
> minimal build).
> - Check which system calls are used by each driver for read and for write
> - Check i18n support.
> - Check distribution packaging
> - Validating that the given build options result in the expect available
> features
> Probably out of scope:
> - Test for support from older platforms & C++ older than C++11
> - Actual sandbox checks
> - Test other bindings to GDAL's C or C++ API such as Fiona & Shapely
> - Integration tests (e.g. GRASS, QGIS, mapserv, GeoDjango, etc).
> - ABI compatibility checks
> - Older versions of dependent libs e.g. netcdf/hdf4/5, kakadu, openjpeg,
> etc.
> -kurt
> Engineer at Google
> On Sat, Sep 5, 2015 at 7:48 AM, Dmitry Baryshnikov <
> <bishop.dev at gmail.com>bishop.dev at gmail.com> wrote:
>> Hi Even,
>> 05.09.2015 17:10, Even Rouault пишет:
>>> Dmitry,
>>> During the code sprint in FOSS4G 2015 (Korea, Seoul) I plan to start
>>>> refactoring Cmake for GDAL (everybody are welcome
>>>> http://2015.foss4g.org/programme/code-sprint/). This is good starting
>>>> point to try release an idea to reformat source tree (combine drivers on
>>>> some principles - raster/vector/raster+vector). I digging the mailing
>>>> list, but didn't found discussion started by Even about this.
>>> Regarding unified drivers, it was a bit mentionned in
>>> https://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification . Basically
>>> the
>>> PCIDSK drivers have been merged in frmts/pcidsk, the PDF ones in
>>> frmts/pdf.
>>> And the raster side of GPKG has been added to the existing
>>> ogr/ogrsf_frmts/geopackage
>>> Potential changes on the tree structure were left out in the "Potential
>>> changes that are *NOT* included in this RFC" paragraph.
>> I plan to experiment with this and if I get good results, RFC will be
>> written.
>>> Also we have
>>>> new type of drivers - network. So, how it'll be best to organise
>>>> sources?
>>>> This can be not only drivers, but the whole source tree. How should the
>>>> ideal GDAL source tree looks like?
>>>> Also I plan:
>>>> 1. Move all internal libraries (zlib, libtiff, libjpeg, etc.) to
>>>> separate github repos to use CMake ExternalProject feature.
>>> Just to give some context: the point for the internal libraries was to
>>> have a
>>> no-brainer way of building GDAL without any prerequisite.
>>> - internal zlib is identical to its upstream v1.2.3 AFAIK
>>> - internal libtiff: most files are identical to libtiff CVS, but a few
>>> ones
>>> (tiffconf.h, tif_config.h) have been modified for integration with GDAL
>>> CPL, and
>>> tif_vsi.c is GDAL specific (I/O implementation) + a build time hack for
>>> TIFF
>>> JPEG 12 bit support
>>> - internal libjpeg is mostly upstream libjpeg v6b + one patch. There's
>>> also
>>> the build hack for libjpeg12
>> I only plan to move this internal libraries in separate repos, not to
>> link official ones. So this is only give more structured sources tree.
>>> 2. Remove any other building systems
>>> That sounds ambitious. Given the complexity and maturity of our current
>>> build
>>> systems, I guess this would take some time to have CMake catch up.
>> Yes, certainly. But anyhow current CMake branch not fully consistent for
>> current build system. So this have to be done.
>>> 3. Try CTest for testing
>>> What do you think it will bring w.r.t our current testing system ? Do we
>>> want
>>> to be dependant of a particular build system for our tests ?
>>> Regarding testing, I've somehow understood Kurt had mentionned plans for
>>> a
>>> "gdalautotest2"
>> This is only subject of experiments. Let's try CTest and see if it fits.
>>> Regarding all the above, I assume you mean in a fork of yours ?
>> Yes. All experiments will be on forked GDAL in separate branch.
>>> As for me the ideal structure should looks like:
>>>> + apps
>>>> + autotests
>>>> + bindings
>>>> + core
>>>>     + port
>>>>     + ogr
>>>>     + gcore
>>> gnm core would go here too ?
>> Yes
>>> + cmake
>>>> + data
>>>> + docs
>>>>     + doxygen
>>>>     + readme
>>>> + drivers
>>>>     + raster
>>>>     + vector
>>>>     + network
>>>>     + combined
>>>> + CMakeLists.txt
>>>> + LICENSE
>>>> So, at the root of sources tree we will have only 8 folders and 2 files.
>>> Is the churn in the tree structure worth the effort ? Be aware that
>>> there are a
>>> number of interdependencies between drivers, so this might require
>>> fixing a
>>> number of source files. What advantages do you see in a new structure ?
>> 1. More ease to understand sources tree for novice.
>> 2. More useful for CMake macro. In current release there are a lot of
>> hardcoded things. Macro give more flexibility.
>> 3. More ease to add some new check needed by separate drivers.
>> 4. More configurable (ease selected depended libraries installed in OS,
>> or should be loaded via ExternalProject), more dependence checks.
>> 5. May be CPack using in future to create distros.
>>> I'm afraid that if you want to change multiple things at a time (build
>>> system,
>>> testing mechanisms, tree structure), you will never manage to get a
>>> working
>>> result. Incremental approaches when feasible are less risky (but
>>> admitedly
>>> involve potentially a larger cumulated effort).
>> Yes, you may be right. But it seems to me that current Cmake version is
>> too complicated than it can be. If Ican improve it it'll solve lot of
>> problems, if not - ok this will be only an unsuccessful experiment.
>>> Even
>>> I do not insist, maybe it's a crazy idea. But as was the discussion of
>> unification, it seemed to me that this worth trying during improvements
>> Cmake build system.
>> Best regards,
>>     Dmitry
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150914/011a3a9e/attachment-0001.html>
