[gdal-dev] PDF Image Rendering issues with Poppler
Even Rouault even.rouault at spatialys.com
Tue Sep 29 00:54:15 PDT 2015
Robert,
Works fine for me with poppler 0.35.0 on Linux and with GDAL trunk.
One key information you didn't mention is your GDAL version. If it is 1.11.2
or older, poppler >= 0.31.0 isn't supported.
See https://trac.osgeo.org/gdal/ticket/6118
You can also test with the builds / SDKs at http://www.gisinternals.com/
Even
>  Gents,
> I downloaded poppler 0.35.0 and used CMAKE to produce VS2012 solution files
> with freetype, jpeg, png, zip, cairo on Windows 7.  I downloaded and
> linked against static libraries of png, lcms2, and zlib. I created a
> simple test PDF and uploaded at:
> http://www.filedropper.com/littlecmslogo If you do not trust the hosted
> source, all I did was took little CMS Logo from their API specifications
> PDF and copy/paste into a new MS Word document with a line of text above
> the logo.  Saved the file as a PDF. Here are a few questions I would like
> to be answered:
> 1. Can someone explain why I cannot render this particular image?  2. What
> type of decoding/rendering issues am I having? 3. Did I forget to include
> another third-party package for poppler?  4. What are the recommended
> settings when building poppler for GDAL usage (i.e., what items within
> poppler should/requires to be enabled) ? 5. If I cannot get an answer for
> that, how can I look into the PDF document hex data or dictionary to see
> how the image was stored?
> Thanks in advance,
> Bob
http://www.spatialys.com
