[gdal-dev] GDAL 2.1.3 with ECW support compile fails
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri May 5 04:40:45 PDT 2017
great, thanks for updating the wiki!   This is great for your karma, and
really helps the next person hitting your issue.
Please always reply to the mailing list.  Have a nice weekend,
-jeff
On 2017-05-05 6:06 AM, Candy, Liam wrote:
> Hi Jeff,
> I was going to update the wiki, but have issues logging in. Anyway, the
> problem was resolved by
> ECWDIR  =   C:\Users\Blah\AppData\Local\Hexagon\ERDAS_ECW_JPEG_2000_SDK_53
> ECWFLAGS = -DECWSDK_VERSION=53 \
>       -I$(ECWDIR)\include \
>       -I$(ECWDIR)\include/NCSECW/api -I$(ECWDIR)\include/NCSECW/jp2 \
>       -I$(ECWDIR)\include/NCSECW/ecw
> ECWLIB  =  $(ECWDIR)\lib\vc120\Win32\NCSEcw.lib
> The main issue was in the DECWSDK_VERSION that I hadn’t configured
> correctly. The ECWLIB also changed for 5.3 vs 4.1
> I then ran into a linking error using VS 2015. The 5.3 SDK appears to
> have been built with an older version of VS, so the linker gives the
> following error;
> odbccp32.lib(dllload.obj) : error LNK2019: unresolved external symbol
> __vsnwprintf_s referenced in function _StringCchPrintfW
> This is resolved by including the legacy_stdio_definitions.lib library
> as an external library in the build. Full resolution to this issue is here;
> https://connect.microsoft.com/VisualStudio/feedback/details/1039102
> Best regards,
> Liam.
> Liam Candy D +27 11 638 2078 M +27 11 282 8658 Ext 8113 2078
> *From:*gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of
> *Jeff McKenna
> *Sent:* Thursday, May 4, 2017 3:11 PM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] GDAL 2.1.3 with ECW support compile fails
> This message originated outside Anglo American
> On 2017-05-04 3:58 AM, Candy, Liam wrote:
>> Hi,
>> I’m hoping someone can help me. I’m trying to build the GDAL 2.1.3 with
>> ECW support (using the Hexagon ERDAS ECW read only SDK v5.3.0).
>> I’m building on Windows with Visual Studio 2015 v14.0.
>> I’m getting the following type conversion errors that are breaking the
>> build:
>> …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(68): error C2440: 'initializing':
>> cannot convert from 'NCS::CString' to 'char *'
>> …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(68): note: No
>> user-defined-conversion operator available that can perform this
>> conversion, or the operator cannot be called
>> …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(1425): error C2664: 'NCSError
>> NCSReadEditInfo(const wchar_t *,NCSEditInfo **)': cannot convert
>> argument 1 from 'char *' to 'const wchar_t *'
>> …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(1425): note: Types pointed to are
>> unrelated; conversion requires reinterpret_cast, C-style cast or
>> function-style cast
>> …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(1485): error C2664: 'NCSError
>> NCSWriteEditInfo(const wchar_t *,NCSEditInfo *,void (__cdecl
>> *)(UINT64,UINT64,void *),BOOLEAN (__cdecl *)(void *),void *)': cannot
>> convert argument 1 from 'char *' to 'const wchar_t *'
>> …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(1485): note: Types pointed to are
>> function-style cast
>> Not sure what I’m doing wrong. Any help would be greatly appreciated.
>> Thanks in advance,
>> Liam.
> Hi Liam,
> I often build MS4W now with ECW support using Visual Studio 2015, mostly
> using the old version 3.3 (read/write) SDK, but also sometimes with the
> 4.x read-only SDK (and I keep my build notes updated at
> https://trac.osgeo.org/gdal/wiki/ECW). I may not have hit your exact
> issue (and version yet), but it would be great if you could also post
> your notes (and gotchyas) on that page as well, so the next person
> coming along doesn't hit your same issue, or at least that the issue is
> known. thanks!
> -jeff
