[gdal-dev] Snowflake Vector Driver
Even Rouault even.rouault at spatialys.com
Tue Aug 30 13:35:00 PDT 2022
Wondering if using the new (Geo)Parquet driver -
https://gdal.org/drivers/vector/parquet.html - wouldn't help for
interoperability with Snowflake ?
At least it should currently understand the non-geo part of it, and I
presume the geo part will come at some point as it seems Snowflake
support, among others, was one of the driver to develop GeoParquet
Le 30/08/2022 à 22:18, Hans Gregers Hedegaard Petersen a écrit :
> Hi Zachary,
>     So, do you know about any efforts to create a Snowflake Vector
>     driver? What would it take for this to happen?
> Please do not see this as discouragement, but we tried to make sense
> out of Snowflakes models (both in and out), and  must say we were
> impressed by their xml-capabilities; they can take any kind of in data
> and make an output model out of it.
> But
> It
> Is
> A
> Pain(!!!)
> To try to figure out anything consistent with the out-model of it.
> A lot of “magic” happens in their mapping, so we basically took a
> handful or two of in data files and reverse engineered (read;
> performed informed guessing) the configuration used for those, so we
> could hopefully produce the corresponding INSPIRE XML configuration
> for GeoServer.
> We found that the same (or so it seemed) Snowflake configuration can
> produce several different outputs depending on version/context/input
> database column configuration etc
> The journey was long, and our client ended up deprecating the services
> with a long notice (counted in years) and built “the same”
> (functionally and not backwards compatible) in a week or two in GeoServer.
> If you need some specific input, I might find an hour or so to
> scavenge our POC. But I am quite sure it is not worth it without the
> snowflake secret sauce.
> Cheers,
> Greg
> *Hans Gregers Hedegaard Petersen
> Partner, Seniorkonsulent
> gregers at septima.dk
> Septima P/S
> Frederiksberggade 19, 2.
> 1459 København K
> www.septima.dk <http://www.septima.dk>
> Tlf: +45 7230 0672
> Direkte: +45 9132 6945
> Cvr: 34900841
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220830/802e6de3/attachment.htm>
