[gdal-dev] PNeo pan-sharpening post 3.7.0
Ferdinand fwschenck at gmail.com
Sat Jul 15 07:13:06 PDT 2023
Hi Evan,
Thanks for the response, I'll give it a go.
As you are on the ticket I mentioned, I assume the rationale behind the
change was to remove the implicit assumption of overlap?
Was there also a subpixel shift then when doing it the "old" way?
Cheers,
Ferdi
On Fri, Jul 14, 2023 at 10:50 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Ferdinand,
> you can for example use "gdal_edit.py -ro -a_ullr X1 Y1 X2 Y2 your.tif" to
> create a geotransform in a sidecar .aux.xml file.  If the pan and ms images
> have the same extent, you could possibly just use -a_ullr 0 0 1 -1
> (untested though). This hypothesis is not totally true as there's some
> subpixel shift for those products between the pan and ms bands if I
> remember well, so you might need to tune that a bit to get optimal results,
> but generally assuming same extent should give you already a decent result.
> Even
> Le 14/07/2023 à 17:36, Ferdinand a écrit :
> Hi all,
> We do stereo photogrammetry on Pleiades/PNeo images, and in one case we
> run our algorithms on pansharpened images.
> Our workflow therefore was that we would pan-sharpen the images and then
> run our stereo processing (using the panchromatic RPC model for the
> pansharpened image).
> However, with the change in this PR:
> https://github.com/OSGeo/gdal/pull/7373 which was integrated into release
> 3.7.0, this is no longer possible. gdal_pansharpen.py now gives: `RuntimeError:
> Panchromatic band has no associated geotransform`.
> What is the recommended workflow for this now? We can't orthorectify the
> images first, as we need the raw row/column information in the image in
> order for the photogrammetry processing to work.
> Is there some other way to add a geotransform that does not require
> warping the image?
> Cheers,
> Ferdi
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230715/4ec307aa/attachment.htm>
