[gdal-dev] GDAL driver plugins on github ?
Andrew C Aitchison andrew at aitchison.me.uk
Wed Jul 19 12:15:08 PDT 2023
On Wed, 19 Jul 2023, Even Rouault wrote:
> Le 19/07/2023 à 16:32, Andrew C Aitchison a écrit :
>> * I have offered another driver as a pull request,
>> but Evan found reviewing my code to be overwhelming.
> Ah ah, apparently those were my own words, seeing
> https://github.com/OSGeo/gdal/pull/4092 . Well, reviewing a new driver for a
> format you're not familiar with is obviously a significant task, that said I
> did an initial review of it and gave some hints to make it progress. For
> major contributions, some tenacity might be necessary to convince grumpy
> maintainers :-)
Evan,
*All* your comments were fair and accurate.
Given that the driver is now available on github and the format is
no longer in active use, I felt that the time you would spend reviewing
the code could probably be better spent elsewhere, at least unless and
until I think my code is better quality.
Thank you for the original review.
Andrew C. Aitchison                      Kendal, UK
