[gdal-dev] Improving details of the project build system and/or documentation
Even Rouault even.rouault at spatialys.com
Mon May 22 07:53:34 PDT 2023
Hi Sean,
I presume you got this because you defined
OGR_BUILD_OPTIONAL_DRIVERS=OFF which then cause OGR_ENABLE_DRIVER_AVC to
be set to OFF.
We already a quite overwhelming amount of documentation in
https://gdal.org/development/building_from_source.html about all the
existing variables, and I'm not sure adding an exhaustive list of all
the inter driver dependencies will be user-digestable and could rot easily.
That said in https://github.com/OSGeo/gdal/pull/7806 I've tried to
improve the current error message with a hint for the reason for the
error and the (likely) reason for it to happen.
I've also added pointers in the doc page to the CMakeLists.txt files
where the dependencies are expressed. Hopefully people who are in the
business of making custom GDAL builds can make sense of that.
Even
Le 20/05/2023 à 01:26, Sean Gillies a écrit :
> Hi all,
> I really appreciate the documentation at
> https://gdal.org/development/building_from_source.html. But there are
> gaps. For example, today I ran into
> CMake Error at cmake/helpers/GdalDriverHelper.cmake:331 (message):
> GDAL_ENABLE_DRIVER_AIGRID cannot be enabled because condition
> OGR_ENABLE_DRIVER_AVC is not met. To ignore this error (but the driver
> will not be built), set the GDAL_IGNORE_FAILED_CONDITIONS variable
> This dependence isn't documented. It's a bit frustrating to work
> through missing directives one at a time when adding new drivers to my
> build.
> Is it possible for a driver's dependencies to be enabled when I enable
> a driver?
> If not, can we consider using GDAL maintenance funding and resources
> on documenting the heck out of this system?
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230522/7bd5e7cb/attachment.htm>
