[gdal-dev] Bumping TileDB minimum from 2.7 to 2.15 for GDAL 3.9?
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Apr 24 15:00:36 PDT 2024
Not knowing any detail about TileDB, I find good this bump in GDAL 3.9.0,
that is already changing many other dependency minimum versions.
On Wed, 24 Apr 2024 at 20:45, Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> A future TileDB version will remove various deprecated API that the GDAL
> TileDB driver currently uses. https://github.com/OSGeo/gdal/pull/9725
> migrates away from those deprecated APIs, but that causes the minimum
> requirement from TileDB to go from 2.7 to 2.15. It would probably be
> wise to backport this cleanup in the 3.9 branch, so that it doesn't
> cause later packaging issues, typically with conda-forge builds as soon
> as they will package the future TileDB version removing the deprecated
> APIs, which might occur during the GDAL 3.9.x life cycle. Does anyone
> see an issue in doing this bump? The few distributions I'm aware of
> shipping TileDB meet the >= 2.15 requirement: Conda-forge already ships
> TileDB 2.22, Alpine Linux is a 2.17.4.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240425/e67fc596/attachment.htm>
