[gdal-dev] Bumping TileDB minimum from 2.7 to 2.15 for GDAL 3.9?
Andrew C Aitchison andrew at aitchison.me.uk
Wed Apr 24 15:39:10 PDT 2024
On Wed, 24 Apr 2024, Even Rouault via gdal-dev wrote:
> A future TileDB version will remove various deprecated API that the GDAL
> TileDB driver currently uses. https://github.com/OSGeo/gdal/pull/9725
> migrates away from those deprecated APIs, but that causes the minimum
> requirement from TileDB to go from 2.7 to 2.15. It would probably be wise
> to backport this cleanup in the 3.9 branch, so that it doesn't cause
> later packaging issues, typically with conda-forge builds as soon as they
> will package the future TileDB version removing the deprecated APIs,
> which might occur during the GDAL 3.9.x life cycle. Does anyone see an
> issue in doing this bump? The few distributions I'm aware of shipping
> TileDB meet the >= 2.15 requirement: Conda-forge already ships TileDB
> 2.22, Alpine Linux is a 2.17.4.
https://docs.tiledb.com/main/how-to/installation/building-from-source
suggests that TileDB requires a C++20 compiler.
Is that an issue ?
Andrew C. Aitchison                      Kendal, UK
