[gdal-dev] Some problems after updating
Even Rouault even.rouault at spatialys.com
Tue Feb 27 11:48:17 PST 2024
Le 27/02/2024 à 20:44, Abel Pau via gdal-dev a écrit :
> Hi Stefan,
> thanks for the answer.
> In my case the gdald.dll with the recent date from my last compilation
> is created directly to build\Debug and not to build\apps\Debug (the
> date it’s older, but not much older, it’s from this morning (??)).
I don't think that a gdal[d].dll file in apps\Debug would be produced by
the GDAL build process itself. That was probably a manual stalled copy
from previous builds. I'd recommend avoiding copying files manually as
that's prone to get out of control and just adjust the PATH.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/b4fa8a54/attachment.htm>
