[gdal-dev] Some problems after updating
Abel Pau a.pau at creaf.uab.cat
Tue Feb 27 11:52:44 PST 2024
HI,
I’m pretty sure (perhaps I’m wrong) that before building the project I’ve deleted the folder buid.
But later I’ll do it again taking care of that and adjusting the PATH from D:\GitHub-repository\GDAL\build\Debug to D:\GitHub-repository\GDAL\build\apps\Debug
A good clue also this wrong PATH! Thanks again!
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: dimarts, 27 de febrer de 2024 20:48
Para: Abel Pau <a.pau at creaf.uab.cat>; Uhrig, Stefan <stefan.uhrig at sap.com>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Some problems after updating
Le 27/02/2024 à 20:44, Abel Pau via gdal-dev a écrit :
Hi Stefan,
thanks for the answer.
In my case the gdald.dll with the recent date from my last compilation is created directly to build\Debug and not to build\apps\Debug (the date it’s older, but not much older, it’s from this morning (??)).
I don't think that a gdal[d].dll file in apps\Debug would be produced by the GDAL build process itself. That was probably a manual stalled copy from previous builds. I'd recommend avoiding copying files manually as that's prone to get out of control and just adjust the PATH.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/d9c36320/attachment-0001.htm>
