[gdal-dev] Where to fins my own files
Even Rouault even.rouault at spatialys.com
Sun Jan 7 13:06:06 PST 2024
Le 07/01/2024 à 21:59, Abel Pau a écrit :
> Thanks for your answers.
> When I call aMMIDDBFFile=CPLFindFile("gdal", "MM_m_idofic.dbf");
> NULL pointer is obtained and I think I know why. When debuging there
> are 2 FinderLocations:
> The first one is “D:\GitHub-repository\GDAL\data;” (note thar there is
> a “;” at the end).
Is the GDAL_DATA environment variable set in your environment ? If so,
just remove the trailing ';' . GDAL_DATA doesn't support multiple paths
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240107/52bdae67/attachment.htm>
