[gdal-dev] gdal2tiles custom tms configuration not found
Andreas Neumann a.neumann at carto.net
Fri Jan 19 03:03:11 PST 2024
Just found
https://github.com/OSGeo/gdal/blob/master/swig/python/gdal-utils/osgeo_utils/gdal2tiles.py#L272
where it seems to look for all files following the naming scheme
"tms_*.json". Therefore I don't know why my custom tms configuration
files is not found - any ideas?
My custom tms json file also has an identifier set to '2056_28'.
Here is the error message I get:
gdal2tiles.py: error: option -p: invalid choice: '2056_28' (choose from
'mercator', 'geodetic', 'raster', 'LINZAntarticaMapTilegrid', 'APSTILE')
Andreas
On 2024-01-19 11:36, Andreas Neumann via gdal-dev wrote:
> Hi,
> I would like to use gdal2tiles with a custom tms profile file. I
> prepared the json file attached in this mail and put this json file in
> the /usr/share/gdal folder, there there are already other such files,
> e.g. from New Zealand or Antartica.
> However, when I try to use this custon tms config, gdal2tiles tells me
> it can't find this profile. Here is my command I used:
> gdal2tiles.py -p 2056_28 -z 16 -w openlayers -t "Swiss Hillshading
> Grayscale" -r cubic -s EPSG:2056 -a 0.0 -e -n
> lv_16_switzerland_hillshading_small-scale_swissalti3d-srtm_100m_jpeg.tif
> tiles
> Do I need to register the custom TMS config json file somewhere in
> addition to copying it to the /usr/share/gdal directory?
> Thank you for your help!
> Andreas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240119/cce4f356/attachment.htm>
