[gdal-dev] false easting and northing units
Even Rouault even.rouault at spatialys.com
Thu Jan 25 08:18:14 PST 2024
Le 25/01/2024 à 17:08, Kirk Waters - NOAA Federal a écrit :
> Even,
> Thanks for the explanation and tips. I'm not clear on how setting to
> 26988 (Michigan North meters) would help.
Hopefully forcing 1.0 will fix the issue.
ah, I didn't realize that the "NAD83 / Michigan North" in your WKT was
*not* official EPSG:26988. I'd strongly suggest you modify your WKT to
use "NAD83 / Michigan North (ftuS)" instead to avoid any confusion!
Actually your WKT is a bit weird as it lacks the name of the CompoundCRS
(quite surprise that PROJ manages to parse it) before the PROJCS[]. Try
the following instead
COMPD_CS["NAD83 / Michigan North (ftUS) + NAVD88 height
(ftUS)",PROJCS["NAD83 / Michigan North
(ftUS)",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",47.0833333333333],PARAMETER["standard_parallel_2",45.4833333333333],PARAMETER["latitude_of_origin",44.7833333333333],PARAMETER["central_meridian",-87],PARAMETER["false_easting",26246666.6666667],PARAMETER["false_northing",0],UNIT["US
survey
foot",0.304800609601219],AXIS["X",EAST],AXIS["Y",NORTH]],VERT_CS["NAVD88
height (ftUS)",VERT_DATUM["North American Vertical Datum
1988",2005],UNIT["US survey
foot",0.304800609601219],AXIS["Gravity-related
height",UP],AUTHORITY["EPSG","6360"]]]
By itself, that will not improve the interoperability, but at least
things will be better labelled, with a GTCitationGeoKey (Ascii,53):
"NAD83 / Michigan North (ftUS) + NAVD88 height (ftUS)"
Even
> If I do a gdal_translate with that, it shows as being in New Zealand,
> just as Arc had done. It would certainly make lots more sense to
> actually put the data in a standard projection that has an EPSG code
> (meters or international feet), but that gets back to the embarrassing
> tale. It may well be that I'll have to force GeoTiff 1.0. I think
> there are other software packages that haven't caught up. Even when
> they do catch up, I've come across people running 15 year old CAD
> software and complaining about the DXF version GDAL produces.
> Thanks to the whole team for the work you do to maintain GDAL.
> Kirk
> On Thu, Jan 25, 2024 at 10:47 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Kirk,
>     perhaps you could try using -a_srs EPSG:26988+6360 instead of a
>     full WKT. That way GDAL will *not* write the projected parameter
>     definitions, but just reference the horizontal and vertical CRS codes:
>     Geotiff_Information:
>        Version: 1
>        Key_Revision: 1.1
>        Tagged_Information:
>           ModelTiepointTag (2,3):
>              0                 0 0
>              440720            3751320 0
>           ModelPixelScaleTag (1,3):
>              60                60 1
>           End_Of_Tags.
>        Keyed_Information:
>           GTModelTypeGeoKey (Short,1): ModelTypeProjected
>           GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
>           GTCitationGeoKey (Ascii,46): "NAD83 / Michigan North +
>           ProjectedCSTypeGeoKey (Short,1): PCS_NAD83_Michigan_North
>           VerticalCSTypeGeoKey (Short,1): Code-6360 (NAVD88 height (ftUS))
>           End_Of_Keys.
>        End_Of_Geotiff.
>     Even
>     Le 25/01/2024 à 16:17, Even Rouault via gdal-dev a écrit :
>>     Kirk,
>>     this is a complicated story indeed... What changed since
>>     https://trac.osgeo.org/gdal/changeset/31405 is that OGC GeoTIFF
>>     1.1 was published, which mostly fixes issues with vertical CRS,
>>     which your CRS uses. So by default GDAL 3.1 or later, when seeing
>>     a CompoundCRS write it as GeoTIFF 1.1, and this new GeoTIFF
>>     version was the opportunity to remove writing the
>>     ProjLinearUnitsInterpCorrectGeoKey=3059 hack, since using GeoTIFF
>>     1.1 is a way to indicate that you're implementing correctly the
>>     standard.
>>     If you force writing GeoTIFF 1.0 by adding -co
>>     GEOTIFF_VERSION=1.0, GDAL will write
>>     the ProjLinearUnitsInterpCorrectGeoKey when needed, and listgeo
>>     will show the "Unknown-3059 (Short,1): Unknown-1" geotiff key.
>>     To know if a Geotiff is 1.0 or 1.1 with listgeo , look at the
>>     Key_Revision in the 3rd line which will be 1.0 or 1.1
>>     So I assume ArcPro doesn't specifically implement 1.1. Either
>>     they implement GeoTIFF themselves, or they use GDAL < 3.1 that
>>     hasn't GeoTIFF 1.1 explicit support
>>     Even
>>     Le 25/01/2024 à 15:24, Kirk Waters - NOAA Federal via gdal-dev a
>>     écrit :
>>>     Hi,
>>>     I've run across an odd issue with GeoTIFFS using custom
>>>     projections written by GDAL and their interpretation in ArcPro.
>>>     The specific case is doing a projection for Michigan State Plane
>>>     North using U.S. survey feet. [insert embarrassing tale of
>>>     another US agency wanting to always use survey feet regardless
>>>     of state legislation or that the federal government has been
>>>     officially metric for a long time]. For a file that should land
>>>     in the Michigan upper peninsula, ArcPro puts it in New Zealand.
>>>     It appears the issue is that Arc is interpreting the false
>>>     easting as meters instead of survey feet. If I do a define
>>>     projection in ArcPro and make a custom projection, it lands in
>>>     the right place.
>>>     I used an old listgeo from the geotiff library to look at the
>>>     tags both in the original file and a copy that had define
>>>     projection applied to see what was different. They looked
>>>     essentially the same, including having the same value for the
>>>     false easting. However, the Arc version had an extra tag (3059)
>>>     that wasn't in the GDAL produced one. An internet search turned
>>>     up this 13-year old GDAL issue
>>>     <https://trac.osgeo.org/gdal/ticket/3901>. If I understand it
>>>     correctly, a bug in GDAL was found that always used meters for
>>>     the false easting and northing. In addition to fixing that, a
>>>     tag (3059) was added to indicate this was fixed so software
>>>     could differentiate broken GDAL output from new output. It looks
>>>     like Arc is looking for this tag and if it's not there, false
>>>     easting is assumed to be meters.
>>>     A few questions, assuming I interpreted that issue correctly:
>>>     1) Why is gdal not adding that 3059 tag? (GDAL command used is
>>>     below)
>>>     2) If it's only supposed to be relevant to GDAL written files,
>>>     why is Arc writing it?
>>>     3) How do I get GDAL to add the tag?
>>>     Command used in file creation:
>>>     gdal_translate -a_srs 'COMPD_CS[PROJCS["NAD83 / Michigan
>>>     North",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
>>>     1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",47.08333333333334],PARAMETER["standard_parallel_2",45.48333333333333],PARAMETER["latitude_of_origin",44.78333333333333],PARAMETER["central_meridian",-87],PARAMETER["false_easting",26246666.6666667],PARAMETER["false_northing",0],UNIT["US
>>>     survey
>>>     foot",0.304800609601219],AXIS["X",EAST],AXIS["Y",NORTH]],VERTCRS["NAVD88
>>>     height (ftUS)",  VDATUM["North American Vertical Datum 1988"],
>>>      CS[vertical,1],  AXIS["gravity-related height (H)",up],
>>>      LENGTHUNIT["US survey foot",0.304800609601], ID["EPSG",6360]]]'
>>>     -co TILED=YES -co COMPRESS=DEFLATE -co PREDICTOR=3 -co
>>>     BIGTIFF=IF_SAFER input.tif output.tif
>>>     Kirk Waters, PhD
>>>     NOAA Office for Coastal Management
>>>     Applied Sciences Program
>>>     coast.noaa.gov/digitalcoast <http://coast.noaa.gov/digitalcoast>
>>>     _______________________________________________
>>>     gdal-dev mailing list
>>>     gdal-dev at lists.osgeo.org
>>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>     http://www.spatialys.com
>>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/b548e45d/attachment.htm>
